Champion 31 spark plug ?
Modeltmike
Last Name: Sleep
* REQUIRED* Type and Year of Model Ts owned: I have 22, 24, 26 coupe, 25 pickup, 23 roadster, 22 center door, 23 touring, 21 touring and 26 Fordson.
Post by Modeltmike » Sat Sep 26, 2020 6:45 pm
I have several champion 31 spark plugs. Can they be used in a model T? When I looked at a crossover chart they they crossover to champion 25. Thanks!
Re: Champion 31 spark plug ?
Post by John kuehn » Sat Sep 26, 2020 7:21 pm
What’s the difference. Heat range or?
BobShirleyAtlantaTx
First Name: Bob
Last Name: Shirley
Post by BobShirleyAtlantaTx » Sat Sep 26, 2020 8:02 pm
By the authority vested in me by a this bunch of outlaws,I hereby grant you permission to use those classic plugs in in your automobile. They should work just fine with a little cleaning. You might try a cotton buffing wheel and red rouge to clean the porcelain.
Susanne
First Name: Susanne
Last Name: Rohner
Post by Susanne » Sun Sep 27, 2020 4:52 pm
It's a commercial application plug, I've seen them in it and miss engines, put a set in an old motorcycle, and I can't see any reason why they wouldn't work in a T.
