Champion 31 spark plug ?
Modeltmike
Topic author - Posts: 180
- First Name: Mike
- Last Name: Sleep
- * REQUIRED* Type and Year of Model Ts owned: I have 22, 24, 26 coupe, 25 pickup, 23 roadster, 27 touring and 26 Fordson.
I have several champion 31 spark plugs. Can they be used in a model T? When I looked at a crossover chart they they crossover to champion 25. Thanks!
Re: Champion 31 spark plug ?
What’s the difference. Heat range or?
BobShirleyAtlantaTx
- First Name: Bob
- Last Name: Shirley
By the authority vested in me by a this bunch of outlaws,I hereby grant you permission to use those classic plugs in in your automobile. They should work just fine with a little cleaning. You might try a cotton buffing wheel and red rouge to clean the porcelain.
Susanne
- First Name: Susanne
- Last Name: Rohner
It's a commercial application plug, I've seen them in it and miss engines, put a set in an old motorcycle, and I can't see any reason why they wouldn't work in a T.
