Vaporizer Carburetor
BLB27
Topic author - Posts: 892
- First Name: Bruce
- Last Name: Brakke
I am trying to disassemble my 1927 vaporizer. I can get all of the bolts loose, but not the vaporizer outlet tube nut. Any suggestions?
Re: Vaporizer Carburetor
Heat & cool.
BLB27
- First Name: Bruce
- Last Name: Brakke
I just can't get it loose. I plant to rebuild the carb so I think I will use a dremel to saw thru the sleeve nut. Any comments?
What Steve said. Turn the nut red and let it cool.
BLB27
- First Name: Bruce
- Last Name: Brakke
Thanks to both Steves. It worked! The bronze nut on the bottom of the carb won't come off. Is it ok to use 'high" heat on it too? Probably a dumb question but I was hesitant because of it being bronze.
BLB27
- First Name: Bruce
- Last Name: Brakke
