1909 firewall trim
Philip Lawrence
Topic author - Posts: 481
- First Name: Philip
- Last Name: Lawrence
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1917 Runabout, 1919 Touring
- Board Member Since: 2014
1909 firewall trim
Can anyone tell me what the correct spacing is for the screws on the brass trim on a 1909 firewall/dashboard is? Also what size screws were used?
Re: 1909 firewall trim
John F. Regan said on Tuesday, August 31, 2010 - 10:31 pm:
'09 screws were in fact #5 oval head screws. The #7 began later and was carried through 1914.
This thread may be of interest but doesn't mention the spacing:
http://www.mtfca.com/discus/messages/11 ... 1283309039
This photo Dan showed in the discussion does show some spacing. I think it may be original.
More insight on it is welcomed.
This is another of Dan Treace's photos.
http://www.mtfca.com/discus/messages/118802/149412.jpg
I don't know the history but the spacing may well be correct.
Jem
- First Name: Jem
- Last Name: Bowkett
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring #9267
Here's my unrestored Aug 09 (not totally unmolested, it had an incorrect repaint circa 1950)
The bottom screw is 1.5" from the bottom edge, subsequent screws are 5.25" apart. The screw is a raised countersunk 1" long with 0.25" wide head.
Mark Nunn
- Last Name: Nunn
This photo of a wrecked '09-'10 was taken in 1913. Timing suggests that nothing was changed from original. This correlates with Jem's photo. It also shows a screw behind the lamp. See the arrow.
Jem
- First Name: Jem
Yes there is a screw behind my lamp
Philip Lawrence
Thanks for all the replies, I think I've got what I need. This is for a friends restoration. It is one of the last things to do. He will I'm sure be very appreciative for the help.
KimDobbins
- First Name: Kim
- Last Name: Dobbins
- First Name: Keith
- Last Name: Townsend
After you drill the holes, and before you put in the brass screws, run a steel or stainless steel screw into the side of the dash to pre-thread the holes in the wood. Brass oval head screws will sometimes twist in two while biting into the wood. Don't ask how I know this...
Philip Lawrence
Keith, thanks for the tip, I'll pass that on to my friend. Running the screw threads over a cake of bees wax is also helpful when installing screws.
