1909 firewall trim
Philip Lawrence
First Name: Philip
Last Name: Lawrence
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1917 Runabout, 1919 Touring
Board Member Since: 2014
1909 firewall trim
Post by Philip Lawrence » Mon Oct 05, 2020 10:55 am
Can anyone tell me what the correct spacing is for the screws on the brass trim on a 1909 firewall/dashboard is? Also what size screws were used?
Re: 1909 firewall trim
Post by Rich Eagle » Mon Oct 05, 2020 11:59 am
John F. Regan said on Tuesday, August 31, 2010 - 10:31 pm:
'09 screws were in fact #5 oval head screws. The #7 began later and was carried through 1914.
This thread may be of interest but doesn't mention the spacing:
http://www.mtfca.com/discus/messages/11 ... 1283309039
Post by Rich Eagle » Mon Oct 05, 2020 12:09 pm
This photo Dan showed in the discussion does show some spacing. I think it may be original.
More insight on it is welcomed.
Post by Rich Eagle » Mon Oct 05, 2020 12:21 pm
This is another of Dan Treace's photos.
http://www.mtfca.com/discus/messages/118802/149412.jpg
I don't know the history but the spacing may well be correct.
Jem
First Name: Jem
Last Name: Bowkett
* REQUIRED* Type and Year of Model Ts owned: 1909 Touring #9267
Post by Jem » Tue Oct 06, 2020 12:15 pm
Here's my unrestored Aug 09 (not totally unmolested, it had an incorrect repaint circa 1950)
The bottom screw is 1.5" from the bottom edge, subsequent screws are 5.25" apart. The screw is a raised countersunk 1" long with 0.25" wide head.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Tue Oct 06, 2020 1:42 pm
This photo of a wrecked '09-'10 was taken in 1913. Timing suggests that nothing was changed from original. This correlates with Jem's photo. It also shows a screw behind the lamp. See the arrow.
Jem
First Name: Jem
Last Name: Bowkett
Post by Jem » Tue Oct 06, 2020 4:10 pm
Yes there is a screw behind my lamp
Philip Lawrence
First Name: Philip
Last Name: Lawrence
Post by Philip Lawrence » Thu Oct 08, 2020 10:45 am
Thanks for all the replies, I think I've got what I need. This is for a friends restoration. It is one of the last things to do. He will I'm sure be very appreciative for the help.
KimDobbins
First Name: Kim
Last Name: Dobbins
Post by KimDobbins » Thu Oct 08, 2020 12:21 pm
Phil, my 1909 dash is also 5.25 spacing.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Sat Oct 10, 2020 7:25 am
After you drill the holes, and before you put in the brass screws, run a steel or stainless steel screw into the side of the dash to pre-thread the holes in the wood. Brass oval head screws will sometimes twist in two while biting into the wood. Don't ask how I know this...
Philip Lawrence
First Name: Philip
Last Name: Lawrence
Post by Philip Lawrence » Sat Oct 10, 2020 3:04 pm
Keith, thanks for the tip, I'll pass that on to my friend. Running the screw threads over a cake of bees wax is also helpful when installing screws.
