What have you done to your T in October?
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Mon Oct 05, 2020 11:44 am
Finish my speedster seats. Look great! Not an easy task...
Super Mario Bross ;)
1911 Touring
1914 Speedster
RFH
First Name: RANDALL
Last Name: HILYER
* REQUIRED* Type and Year of Model Ts owned: 1919 COUPE
Re: What have you done to your T in October?
Post by RFH » Mon Oct 05, 2020 1:47 pm
I rebuilt my muffler.
Sounds much better !
dhosh
Last Name: Hoshield
* REQUIRED* Type and Year of Model Ts owned: '24 RPU (Raodster converted to Pickup)
Post by dhosh » Mon Oct 05, 2020 9:22 pm
...007 ...
WOAH! BEAUTIFUL!
'24 RPU
Petoskey, Mi
dhosh
Last Name: Hoshield
Post by dhosh » Mon Oct 05, 2020 9:29 pm
RFH ...
Look'n good! I had often thought about replacing my stainless muffler with a quieter one and always thought this type would be quieter and certainly more authentic.(don't mean to start a thread on muffled again! LOL) I guess I hadn't noticed before .. I'm surprised the exhaust isn't at the bottom. Are they supposed to be on the side, or is that just where it ended up, or ?????
'24 RPU
Petoskey, Mi
Post by Allan » Mon Oct 05, 2020 10:07 pm
Dennis, each cast iron end of the early mufflers has an integral mounting cast into it. They can only be mounted one way, unlike the circular pressed steel front end of a later muffler. The brackets always determine the orientation of the ends, although you might be able to have some fun with the really early bolt on brackets, but then the integral tailpipe would be out of kilter.
dhosh
Last Name: Hoshield
Post by dhosh » Mon Oct 05, 2020 10:36 pm
Ahh... Very good... Thanks for the explanation!
Dennis
'24 RPU
Petoskey, Mi
Post by Steve Jelf » Tue Oct 06, 2020 12:40 am
Today I finished straightening mag coil ribbons.
The outlay for my straightener was under $20. I paid $5 each for the two locking pliers, and $7.77 for the square tubing. All the other parts are stuff I had on hand.
The square tubing serves as an anvil if the ribbon has a spot that requires flattening with a small hammer. That's mostly not needed. The stretcher pulls the ribbons pretty straight.
Some of the ribbons had a few rough spots that needed filing.
The final step is wire brushing to remove any little bits of old insulation that may have survived the cleaning.
All 32 ribbons straightened and ready for new insulation and rewinding into new coils.
david_dewey
First Name: David
Last Name: Dewey
Post by david_dewey » Tue Oct 06, 2020 1:15 am
Hmm, does patting the fenders of Barney and using Barney to stack some boxes on while I was looking for something else count? So far that's all I've done! :D
T'ake care,
David Dewey
Bill Dizer
First Name: Bill
Last Name: Dizer
Board Member Since: 2014
Post by Bill Dizer » Tue Oct 06, 2020 1:28 am
The end of the muffler has the mount made on it that bolts to the frame, so that is where the outlet has to go.
Post by Mark Gregush » Tue Oct 06, 2020 1:41 am
From the encyclopedia (early mufflers had cast ends with two bolts of the 3 holding the brackets on front and rear):
REAR HEAD
1909
----- 1201 Separate tail pipe, F/N 1213
1909-1910
4040 1221 Steel brackets, straight pipe.
1911-1914
4040 1221 Steel brackets, curved pipe
1914-1917
4040 1221B Integral bracket, straight pipe with no taper.
1917-1920
4040B 1201D Integral bracket, no pipe. Shorter mounting bracket.
In June 1919 the exhaust opening was moved ten degrees to direct exhaust away from the spare tire.
1921-1926
4040C 1201E Pressed steel, no pipe. Integral mounting bracket was on the rear cap only.
1926-1927
4040D 1209
RFH
First Name: RANDALL
Last Name: HILYER
Post by RFH » Tue Oct 06, 2020 7:14 am
Thanks Mark for all the muffler info
My car is a 1919 Coupe
With the outlet as it is the exhaust exits between the rear axle and the spare tire carrier
Works Great.
Lots of good info here
Thank you,
RFH
Nunsio1
Last Name: Monticciolo
* REQUIRED* Type and Year of Model Ts owned: 1924 C Cab truck
Post by Nunsio1 » Tue Oct 06, 2020 7:53 am
24 C Cab almost finished,just stain & rear fenders next.. built from loose parts-20 yr project
John
Oscoda Michigan
Last Name: Strange
Post by CudaMan » Tue Oct 06, 2020 7:58 am
Beautiful! :)
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Tue Oct 06, 2020 9:30 am
Good looking truck John. Good use of spare parts.
TheSaintDiscJockey
First Name: Brooks
Last Name: Schlieben
* REQUIRED* Type and Year of Model Ts owned: 1923 TT
Post by TheSaintDiscJockey » Wed Oct 07, 2020 1:53 pm
October in Pennsylvania is a great month to wrap up some outdoor painting projects.
Did some wheel painting this week. Rather pleased with the results.
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Thu Oct 08, 2020 4:17 pm
Finish to paint my 1914 chassis (Frame) I will start to reassembling the car by now
1911 Touring
1914 Speedster
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Thu Oct 08, 2020 6:10 pm
Nothing on the T but started prepping for my new workshop for the T's. This charming structure had to come down 1st.
Not all is lost. Alot of the structure will be used to finish the inside of my shop.
Last Name: House
Post by George House » Thu Oct 08, 2020 6:37 pm
While driving my ‘26 tudor Saturday midnight as the getaway car for a wedding, I determined the slop or ‘play’ in the steering was unacceptably high. I traced the problem to the top steering gear pin. It was wallowed out in the shaft. So I researched fixes in archived Forums but decided a brand new $330 Snyder’s shaft, gears, pins and central gear and steering wheel shaft would be safer. Should receive it tomorrow. Anyone want the well greased old unit ?
NealW
First Name: Neal
Last Name: Willford
Post by NealW » Sat Oct 10, 2020 4:15 pm
One of my nephews who's a pilot for Delta had a layover in Wichita last night, so I gave him his first ride in a T out to Stearman Field restaurant for lunch today. In addition to fly in customers, the restaurant is also quite an attraction for motorcyclist on a good day for a ride.
I have discovered that motorcyclists will often waive when passing me while driving a T. I suspect T drivers are accepted as "honorary motorcyclists" by them! The ride certainly is more like theirs than a modern car.
Jack Putnam, in Ohio
First Name: Jack
Last Name: Putnam
Just Wheeling, lots of wheels in process
Post by Jack Putnam, in Ohio » Sat Oct 10, 2020 9:30 pm
This past few weeks I have determined it was time to sort out my wheel collection. The good , the bad and the ugly, you know the story. The ugly I have trashed as they had no salvageable pats that were usable. The good ones I have restored or they are in the process of restoration. I found that I have sets non demountable, a set of Hayes demountable, a set of Firestone demountable, a set of non demountable to go to the wheel wright. Kelsey, Hayes, Firestone and Ford wheels are represented. These are all for the clincher tires and I have not even looked at the later balloon tire wheels. There are two sets of Stutzman respoked wheels in the group that are ready to go.. I'm wheelly crazy! :D
Bill Coyle
First Name: Bill
Last Name: Coyle
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster
Post by Bill Coyle » Sat Oct 10, 2020 9:54 pm
Did a little off roading on my way to Elmore, OH this afternoon. There's nice scenery and little traffic driving along the river road. Unfortunately the leaves won't be hanging on too much longer... Bill
Post by Mark Gregush » Sat Oct 10, 2020 10:09 pm
Nothing on the T's, but have been doing some work on the 1920 Dodge.
EricMac
First Name: Eric
Last Name: Macleod
Post by EricMac » Sat Oct 10, 2020 11:53 pm
I fixed a flat on mine with a bit of help from my friends.
Fordor at Gilmore tour
1913 Touring
1926 Touring (2006 Stynoski)
1927 Fordor
1926 Depot Hack project
Burger in Spokane
First Name: Brent
Last Name: Burger
Post by Burger in Spokane » Sun Oct 11, 2020 1:08 am
Picked up a pallet (42 sacks) of 80lb. concrete and some rebar and forming
lumber. The old dog had no issues, but I misjudged the need for Ruckstell
low to make the hills, and stalled out. Once downshifted, we pulled the rest
with no trouble at all. I figure the load scaled out at about 3500lbs. The truck
rides REAL smooth with that kind of weight on it, but care must be taken to
ensure adequate braking distance is considered !
Last Name: House
Post by George House » Sun Oct 11, 2020 4:08 pm
I replaced the steering shaft, gears and pins in my ‘26 tudor. Drove the car for the first time in years last Saturday night and considered 4” steering wheel play was too much. That Texas T Parts unit is great !! Did have to grind about 1/32” off that top, long pin. Task was easily accomplished without removing the column. Take about an 18” piece of wood with a multifolded cloth on top to place under the horn tube after column is dropped to enable old and new shafts replacement. Removed 6 bolts from firewall, 4 from dash panel under the column and horizontal longbolt holding the lower steering frame bracket. Also the rear bolt and loosened the front bolt. Was surprised how easy the pitman arm removed. The 2 old keys fit into the new machined keyways perfectly. Took her out for a test drive after a few beers and was amazed! No steering slop now😁🍺
david_dewey
First Name: David
Last Name: Dewey
Post by david_dewey » Sun Oct 11, 2020 5:37 pm
Burger 42 sacks of concrete??? sounds like you’ve got a major project going on — I will avoid visiting for a while in that case :)
T'ake care,
David Dewey
Burger in Spokane
First Name: Brent
Last Name: Burger
Post by Burger in Spokane » Sun Oct 11, 2020 6:34 pm
42 was just half of the total. Footings and stem wall for foundation repair/update,
and 18x8 slab. We'll pour the slab mid-week, so feel free to drop by any time after
that. :lol:
Last Sunday I took a 10 hour looping jaunt into the Big Bend and Scablands. This is
WHY I own a truck like mine.
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Sun Oct 11, 2020 7:09 pm
Best relaxation I can think of Burger! Driving a TT into the wild blue yonder is good therapy.
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Sun Oct 11, 2020 7:21 pm
Rebuilt the top assembly and installed the top on my 23 runabout.
NU2theT
Last Name: Wendt
Post by NU2theT » Sun Oct 11, 2020 7:42 pm
Got some stop/turn lights mounted to the bumpers, hope to finish wiring tomorrow. Nice kit from Logo Lites in Duluth GA, great installation instruction and nice quality parts.
www.logolites.com
Got the LED's in as well today, big difference from the available China glass bulbs.
Last Name: House
Post by George House » Mon Oct 12, 2020 12:12 pm
Top is looking good Mark. That’s a job that needs to be done before winter all right.😁
Post by Rich Eagle » Mon Oct 12, 2020 12:49 pm
The pleasant whiff of gasoline on our drives had increased to the obnoxious stage. I was blaming the gas cap until the other day when evidence of a leak appeared on the splash apron. The pervious day presented a narrower area but overnight the full truth showed itself.
Removal of the tank revealed the extent of the spillage. I should note that the hold down screw was my solution and not what may have been original. Also, my outlet from the sediment valve is too high and required a severe bend of the gas line. I suspect the tank sat lower than mine does.
The lower seam on the right side was side was leaking. I had soldered a few spots and used gas tank sealer in 2013. This is the first occasion I have encountered of the sealer failing. My first attempt to re-solder didn't accomplish much. I thought it was a lost cause and looked at buying a new tank. However the next day I tried a larger electric iron which got the metal hot enough to make a better seam. Without being able to clean the part of the joint between the two sheets this solder at the edge will not be nearly as strong. It showed no leakage overnight. I will clean inside the tank with lacquer thinner and pour some sealer into that part of the tank. We will watch carefully for any further leakage.
It is very frustrating when I can't repair these things myself. Thankfully, another day and bigger iron made the task rewarding. Ironically, the larger iron was presented to me after Joy's Father's funeral several years ago. It was my inheritance. She say's it was meant to be.
There are a lot to jobs like soldering that can't be mastered without some practice and knowledge. Getting the metal clean is the key here.
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Tue Oct 13, 2020 1:23 pm
Hi Rich,
I used this product Permatex Fuel repair tank several year ago with my 1911 and still working. You could use the product with the gas in and make a little pression for couple minutes. It dry in less of 1 hour. No welding necessary. I was really surpise by the result.
1911 Touring
1914 Speedster
Post by Rich Eagle » Tue Oct 13, 2020 3:43 pm
I'm glad to hear those results Mario. I have a stick that looks like that which I bought a dozen years ago and never tried. If I had known it works I might have tried it instead. I know soap works temporarily too.
EricMac
First Name: Eric
Last Name: Macleod
Post by EricMac » Tue Oct 13, 2020 7:03 pm
Well...not a good thing but I think I broke the thrust washers, ring and pinion in my Fordor. Thats sort of last nail in the coffin. Time for full restoration.
1913 Touring
1927 Fordor
John Dow
Last Name: Dow
Post by John Dow » Tue Oct 13, 2020 7:03 pm
I joined the two piece crankshaft club.
Susanne
First Name: Susanne
Last Name: Rohner
Post by Susanne » Tue Oct 13, 2020 7:19 pm
Owww!!! Sorry, that sux!
BobShirleyAtlantaTx
First Name: Bob
Last Name: Shirley
Post by BobShirleyAtlantaTx » Fri Oct 16, 2020 7:32 pm
For a Holley G, an hour and a half I’ll never get back.
Post by Rich Eagle » Sat Oct 17, 2020 11:44 am
I need to do that too Bob.
I designed and built this stand for my coffee cup. For 42 years I have been going out to the shop with a hot cup of coffee. I either had to hold the top of the hot cup with my other hand while I got the keys out of my pocket or set it down on the stoop. I often thought of a shelf or pedestal to set it on but now I have one.
Simple?
NealW
First Name: Neal
Last Name: Willford
Post by NealW » Sat Oct 17, 2020 1:06 pm
Last spring when I finished restoring our 15 runabout, I reinstalled the leather fan belt that came with the car because it appeared to in good shape. However, when tightened it, the belt was right up to the big bolt holding the fan onto the engine. That didn't look right, so I finally got a new 23" leather belt and installed it, along with a new arm because the nub that the tightening bolt was worn. Now it clears everything, as it should! I was surprised how much the old one was stretched - over one inch longer. No wonder it wasn't fitting right. It also was starting to fail at one spot on the inner surface.
I also installed one of Tim Morsher's RAJO oil gauges, which I think looks cool if anything. Last month I installed his replica gas gauge, which is nice to have too. I've been still dipping the tank to see how well it compared to the 'stick'. The last tick mark before empty is 2 gallons for my round tank, which is as low as I like to let my tank get.
Model T Mark
Last Name: Eyre
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring 1914 Touring and Roadster 1915 Touring 1926 Roadster
Post by Model T Mark » Sat Oct 17, 2020 3:23 pm
Beautiful 15 ford engine compartment. One question is the bolt that holds the fan arm on missing the cotter pin behind the timing gear cover? I have seen those bolts back out and destroy a brass radiator. Just trying to save a catastrophe.
NealW
First Name: Neal
Last Name: Willford
Post by NealW » Sat Oct 17, 2020 5:51 pm
Yeah, that's a good catch. Thanks. I just put one in. I don't want my nice Brassworks radiator chewed up! I also checked our 21 touring and it was also missing a pin in the fan bolt, so I added one there too!
John Warren
Last Name: Warren
Post by John Warren » Sun Oct 18, 2020 11:06 am
Rich, that is funny and looks like it will work well, I know exactly where that is. It was absolutely wonderful to meet you!
Post by Rich Eagle » Sun Oct 18, 2020 12:19 pm
It was great to see you. I haven't heard from the racer owners but assume progress is underway.
My1914T
First Name: Ross
Last Name: Benedict
* REQUIRED* Type and Year of Model Ts owned: 1920 Drs. Coupe
Post by My1914T » Sun Oct 18, 2020 3:29 pm
Up on it's frame and casters, so I can stow it away. Pulling headlights to be repainted, Hope to see it again in March. Brrrr.
Last Name: Juhl
Post by Oldav8tor » Sun Oct 18, 2020 7:30 pm
Took a overnight tour with eight other cars from Vestaburg in mid-Michigan to Jugville's log hotel (The Shack) located on a lake near Fremont. Friday saw cold, rain and frozen pellets (a thunderstorm overnight) while the return on Saturday was just cold. By cold I mean a little either side of 50 degrees. Despite the unseasonable weather a good time was had by all as we Michiganders are a hardy folk. The hotel was nice and an evening bonfire by the lake was enjoyed by all.
Frozen pellets / rain at our ice cream stop....as if we weren't cold enough :-)
Dining room at the Shack
dhosh
Last Name: Hoshield
Post by dhosh » Sun Oct 18, 2020 9:20 pm
Finally got this thing back together enough to do a short test run. Been sine early spring. Valve job, new head, rebuilt steering column, bushings, sin gears and pins, new brake drum and shaft, driven gear, more bushings, watts clutch disks, resurfaced reverse drum, rebuilt hogs head, changed to wood bands, new speedometer replacement for the ammeter, new pan and head bolts (longer). I'm sure I've forgotten stuff! Hope to get it out on the road tomorrow for a test spun!
https://m.facebook.com/story.php?story_ ... 1622598727
'24 RPU
Petoskey, Mi
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Mon Oct 19, 2020 9:53 am
STAINING AND VARNISHING MY 1914 SPEEDSTER BODY
1911 Touring
1914 Speedster
modernbeat
First Name: Jason
Last Name: McDaniel
* REQUIRED* Type and Year of Model Ts owned: 1913 Roadster / 1926 Pickup / 1926 Express-Camper
Post by modernbeat » Mon Oct 19, 2020 11:59 am
Finally got my custom high compression pistons for my camping car in from Wiseco.
Finished the drop gate bed for the same truck and started painting it, then started working on the firewall.
Rebuild the adjusters on the '26 headlights with LED bulbs.
Jason McDaniel
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Mon Oct 19, 2020 2:29 pm
I was, finally, able to remove the adjustable yoke from my tie rod. It appears to have been stuck for many decades and took many heat and soak cycles. Now I need to get the pitman arm off to replace it. I'm running out of bigger hammers. I might try to make a puller if I can't find one the right size.
John Dow
Last Name: Dow
Post by John Dow » Mon Oct 19, 2020 10:22 pm
As previously reported I broke my crankshaft. I have now pulled the engine, loaded it into my pickup and I'm headed to the rebuilder in the morning.
Last Name: Strange
Post by CudaMan » Tue Oct 20, 2020 11:40 am
I pulled Betsy's winter front and hood blanket out of storage and installed them on the car today. A little early, but the winter front flap exposes the entire radiator opening when it's rolled up, so theoretically it could stay on year round. The camera flash makes the vinyl look gray, but it is black to the naked eye. :)
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Tue Oct 20, 2020 1:42 pm
Thats's realy cool Mark!
1911 Touring
1914 Speedster
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Fri Oct 23, 2020 10:57 am
Finished several items this week for my stock 1914 speedster: Tail light, monocle glass. and Disck wheel. I hope making my first fire-up engine gine this Sunday!
1911 Touring
1914 Speedster
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Fri Oct 23, 2020 11:00 am
1911 Touring
1914 Speedster
Post by RajoRacer » Fri Oct 23, 2020 11:09 am
Just a "heads-up" on your disc wheels - the rim bolt should be parallel to the rim not crossways. I have the same discs on my Racer.
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Fri Oct 23, 2020 11:49 am
Thank you Steve, I am questioning my self when I installed the bolts... Which side ? Now I know. :lol:
1911 Touring
1914 Speedster
Burger in Spokane
First Name: Brent
Last Name: Burger
Post by Burger in Spokane » Sat Oct 24, 2020 6:21 pm
The weatherdude called for snow on Friday, starting around 1100hrs, so a run up to
the stretch of road by the golf course was in order, to rake fallen pine needles while
they were still nice and dry. Got 10 trash cans put up for fire starter for the winter.
Then headed off to load up some maple rounds we took down last winter and left out
all summer to dry. Got the old dog into the shop as the white stuff began to fall. Pulled
a fresh tarp over the stack we got on the first load, and headed off to work. Before
the end of the day, we had nearly a foot of snow on everything. Timed this one perfectly.
Last edited by Burger in Spokane on Sun Oct 25, 2020 1:27 pm, edited 1 time in total.
Ken Lefeber
First Name: Ken
Last Name: Lefeber
Post by Ken Lefeber » Sat Oct 24, 2020 6:42 pm
Gave my niece a ride through the kettles in Wilma. It was one of those days I'm glad I have an enclosed car. :D
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Sat Oct 24, 2020 7:51 pm
Burger, that is great to see thar TT hard at work again after its short rest.
Post by Mark Gregush » Sun Oct 25, 2020 2:11 am
The 21 has been hard to start lately so I did some checking today. I knew it was not spark or timing so that left fuel. Found that the intake gland ring in the rear port was not entering the hole in the block and was riding on the outside of the block, so was not sealing real well, fixed it. Battery is going so have to hand crank most of the time, not fun with that vacuum leak! Was taking a lot of cranking to pull the fuel up before it would fire. Now it is back to normal. :) I also gave it a quick bath and took it out for a short drive. You will note I am moving from it's given name of Nelly-Bell or her/she to "it". I am starting to distance myself from it, if you get the hint of what is going on and the direction I am headed without me coming out and saying it.
Rich in Colorado
Last Name: Carlson
* REQUIRED* Type and Year of Model Ts owned: 1922 Center Door 1923 Touring
Post by Rich in Colorado » Sun Oct 25, 2020 1:12 pm
Re-shod the ‘22. Firestone’s
Rich in Colorado
1922 Model T Center Door
1923 Model T Touring
1928 Model A Tudor
1956 Ford Thunderbird
1966 Ford F250 Camper Special
ryanf1023
First Name: Ryan
Last Name: Fenrich
* REQUIRED* Type and Year of Model Ts owned: Speedster Project
Post by ryanf1023 » Sun Oct 25, 2020 2:59 pm
Made some good headway on the coil box. Won't be finished until I get a new soldering iron
dhosh
Last Name: Hoshield
Post by dhosh » Sun Oct 25, 2020 8:18 pm
Swallowed my pride, and pulled my engine again, after only running it about 5 minutes after a months long rebuild. Apparently, snapped a triple gear pin.
Drove it 6 hours south to Joe Bell, to fix properly. On the positive side, I should have replaced the ring gear before! 😜
'24 RPU
Petoskey, Mi
Post by Mark Gregush » Sun Oct 25, 2020 8:43 pm
I would not suggest doing any soldering with the parts assembled. The stuff is water proof but not sure how soldering iron proof it is.
AndreFordT
First Name: Andre
Last Name: Valkenaers
Post by AndreFordT » Wed Oct 28, 2020 2:02 pm
Some time ago I was looking for a fine sorceress to rebuild a few coils. The good witch came by and give me a hand to clear the job.
Now I should like she came back again to help me with the rebuild of a 1913 engine and set an electric starter on it.
Here a few photos.
A lot of safety wire was missing. The lower magneto coil ring bolts came out by hand. The wrist bolts are normal bolts no safety wire. The cylinder head gasket was on it up side down. Starting the engine give directly water that came out of the radiator. The fourth piston had no carbon on it it was clean as new, the one that had a water leak due to the wrong way the gasket was mounted. The nuts on the meanbearings are normal nuts not the castellet one, and so on.
Just needed an electric starter, it will be a total rebuild at the end.
Andre
Belgium
rlcxz@yahoo.com
Last Name: Cook
* REQUIRED* Type and Year of Model Ts owned: 1922 1917
Post by rlcxz@yahoo.com » Thu Oct 29, 2020 2:54 pm
Had radiator repaired because the Motor Meter was so heavy that the vibrations caused the filler neck to break where it was solder onto the tank. All back in and no leaks.
John Codman
Last Name: Codman
Post by John Codman » Fri Oct 30, 2020 1:23 pm
Conducted a 'speriment - My '27 has a Berg's flat-tube radiator installed in 2014. It has cooled beautifully ever since the day I installed it. Today with my DVOM I measured the temperature drop from the top to bottom of the radiator. Idling in our garage, I waited for the temperatures to stabilize; the ambient temperature was 89 F. The temperature at the top of the radiator was 170 F, the bottom was 116 F. A drop of 54 degrees. Now I know why there have been no cooling issues even on the hottest Florida days.
Post by Mark Gregush » Fri Oct 30, 2020 9:54 pm
Tomorrow I will be draining everything motor and Warford related so I can pull the engine and Warford. The clutch; pins are below the surface so the adjusting screws are going in to the hole. I think the pins may have started working under the drive plate and are jamming the clutch part way engaged. Once the car is running seem ok after the pins work back into the holes were they should be. I have a cut down 26/27 drum installed, the drive plates are a bit thinner then the earlier ones anyway so does not take much to start working out of the hole and underneath it. I have 2 sitting on the shelf that just that had happened when I got them. I know the disk count was correct, more then double checked when installed. If the driving plate isn't too boogered up and if there is room thinking about just adding extra disk or two if the extra rings I have don't clean up. The Warford; while the engine is out want to re-check the preload, I think it's a bit on the loose side so want to reset it if needed.
ITDave
First Name: David
Last Name: Flowers
* REQUIRED* Type and Year of Model Ts owned: 1926 Coupe, 1927 Coupe
Post by ITDave » Mon Nov 02, 2020 4:05 pm
I replaced 4 tires, tubes and flaps on my '27 Coupe back in August. Got to do my first flat fix in October. I went out in the shop and noticed that my right rear tire was flat. Picked up a roofing nail. It isn't that hard of a job but I'm going to need a better turn buckle to pull in the 21" split rims.
modernbeat
First Name: Jason
Last Name: McDaniel
Post by modernbeat » Mon Nov 02, 2020 4:13 pm
This is where we were at the end of October.
Lower body mainly finished except the floorboards over the transmission.
Getting started on the roof for November.
Jason McDaniel
