My soon to be Centerdoor chassis came with accessory APCO ball connections.
So did my current touring chassis.
The only items I replaced is the spring, cup and cotter pin. The screw adjustment is original and in perfect condition
APCO
Topic author - Posts: 933
- First Name: William
- Last Name: Vanderburg
Re: APCO
The APCO came with good adjuster. I have seen some other brands that were pot metal, real buggers to get out.
Re: APCO
Yes, you are so correct. I have an extra one with no hope of ever getting the adjuster out of it.Mark Gregush wrote: ↑Fri Nov 13, 2020 6:10 pmThe APCO came with good adjuster. I have seen some other brands that were pot metal, real buggers to get out.![]()
William L Vanderburg
1922 Center Door Sedan
