APCO
Will_Vanderburg
First Name: William
Last Name: Vanderburg
APCO
Post by Will_Vanderburg » Fri Nov 13, 2020 2:35 pm
My soon to be Centerdoor chassis came with accessory APCO ball connections.
So did my current touring chassis.
The only items I replaced is the spring, cup and cotter pin. The screw adjustment is original and in perfect condition
William L Vanderburg
1922 Center Door Sedan
Re: APCO
Post by Mark Gregush » Fri Nov 13, 2020 6:10 pm
The APCO came with good adjuster. I have seen some other brands that were pot metal, real buggers to get out. :(
Will_Vanderburg
First Name: William
Re: APCO
Post by Will_Vanderburg » Fri Nov 13, 2020 7:05 pm
Yes, you are so correct. I have an extra one with no hope of ever getting the adjuster out of it.
