1915 Hight F Hub Cap
Vrayfoster
Topic author - Posts: 75
- First Name: Victor
- Last Name: Foster
- * REQUIRED* Type and Year of Model Ts owned: 1910 Touring, 1915 Touring
- Board Member Since: 2002
The one on the left is an original high F hub cap found on 15 cars. My home made one is on the right. It isn't a perfect copy.
Re: 1915 Hight F Hub Cap
I hate to disagree with you, but the hubcap you have pictured is a 1913 high F hubcap. Should you wish a photo of a correct 14-16 high F hubcap I'll be happy to send you one.
- First Name: Keith
- Last Name: Townsend
Victor-
Is that the blank "no script" hubcap that Lang's has available?
Very clever. How did you do the logo?
The attached image is a hubcap with the high F script used in 1915-1916 (same hubcap, nickel plated was used in 1917)
I suspect in about 1918 when hubcaps were produced in all corners of the country is when the letter (or sometime star or symbol) was added below the "made in USA"
The current reproduction hubcap which are listed as 1913-1927 look like they come out of the same machine, but they simply change the finish from brass to nickel (or chrome.)
Thanks for posting a correct 14-17 hub cap. Of course the '17 is nickel.
Benji
- First Name: Benjamin
- Last Name: Eckstein
- * REQUIRED* Type and Year of Model Ts owned: 24 Roadster Pickup, 13 Runabout, 13 Touring, 14 Light Delivery, 15 Speedster
- Board Member Since: 2012
Looks great! How did you make it?
