26 Roadster Steering column
Bill Coyle
First Name: Bill
Last Name: Coyle
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster
Post by Bill Coyle » Tue Apr 06, 2021 1:56 am
On the 26/27 coupe, roadster, touring, and tudor, which side of the firewall should the steering column flange mount ? I've looked over quite a few pics on the net and it seems both ways are quite common. I believe on the pre 26 models they all mounted to the inside (passenger side) of the firewall.
I'm thinking the 26/27 also mounts on the inside. As a side note, I've found earlier threads showing two styles of the bottom bracket. They are mounted on the outside (engine side) of the firewall.
Thanks, Bill
Re: 26 Roadster Steering column
Post by Mark Gregush » Tue Apr 06, 2021 3:22 am
RE; I'm thinking the 26/27 also mounts on the inside. As a side note, I've found earlier threads showing two styles of the bottom bracket. They are mounted on the outside (engine side) of the firewall.
Correct, column on the inside bracket on the outside.
Brian D
First Name: Brian
Last Name: Dowell
* REQUIRED* Type and Year of Model Ts owned: 14 Touring 26 Runnabout 19 Canadian Touring
Post by Brian D » Tue Apr 06, 2021 3:40 am
Flange is on the inside. 26/27 flange is round.
Life is Good, be nice.
Post by Allan » Tue Apr 06, 2021 5:41 am
On our Canadian sourced cars, the 26-7 flange is square. It is an east way to distinguish them from earlier columns, especially when looking for a set of 5:1 components.
Roffe
First Name: Rolf
Last Name: Oehman
Post by Roffe » Tue Apr 06, 2021 5:59 am
I agree with Allan. I think square flange is correct for the 1926-27 roadsters. At least it is on mine. Flange on the inside and brackets on the engine side of the firewall.
Roffe
First Name: Rolf
Last Name: Oehman
Post by Roffe » Tue Apr 06, 2021 6:02 am
Looking closely at the photos it looks lik there is a bracket on both sides of the firewall.
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Tue Apr 06, 2021 7:26 am
Bill, 26-27 steering column flange is square, mounts to the inside of the firewall. The spacer bracket mounts on the outside of the firewall. There is also a picture in the Ford Service Manual Fig 563, not very clear in the new reprint manuals but does show up clearly in the original hard cover manual.
Post by DanTreace » Tue Apr 06, 2021 9:15 am
And...two styles of the steering gear to dash covers for '26-'27, the Fordor is unique.
The steering column mounts inside. The dash cover mounts outside the dash/firewall, that way the 2 upper holes in the steering column square flange line-up to the dash cover, that provides the lower 2 holes for the steering column square flange. And the dash cover lower edge holds the floorboard.
Bill Coyle
First Name: Bill
Last Name: Coyle
Post by Bill Coyle » Tue Apr 06, 2021 9:51 am
Thank you for the help and quick response!! I changed out the original one because it was loose where the gear case is pinned to the column. When I'd turn the steering wheel the gear case would rotate opposite a half inch.
I had the replacement one on the inside, but saw markings on it indicating it was mounted previously on the outside... so I changed it. Guess I'm moving it back to the inside today where it should be. My friend told me Any job worth doing is usually done twice!!
....sometimes more!!
Bill
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Tue Apr 06, 2021 6:26 pm
Mine is square and I just finished installing it for the third time 😳
I had mine on the outside and things didn’t go right with the bracket on the lower two holes. So I pull it out and get it all in there nice and pretty like. I was proud of myself until I tried to bolt the dash in place. What was in my way but the steering column. I am good at it now if you need a hand.😁
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Tue Apr 06, 2021 6:30 pm
I am missing the bracket that supports the column to the dash. I didn’t see anything the vendors offer for this. Is this a bracket I need to beg for here on the forum? Mine is 26/27 also
Post by TRDxB2 » Tue Apr 06, 2021 6:51 pm
I have one if their out of stock https://www.modeltford.com/item/3500D.aspx
This steel brackets mounts onto the steel dash panel, just below the steering column and helps to support it.
It is a reproduction of the original bracket which is so hard to find and often missing.
Fits all 1926-1927 car bodies.
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Tue Apr 06, 2021 7:30 pm
I will check
Bill Coyle
First Name: Bill
Last Name: Coyle
Post by Bill Coyle » Mon Apr 12, 2021 5:09 pm
In and hooked up! On the dash, I remember reading about a padding that went between the column and the lower bracket. Does anyone use it? I still have the original padding between the dash and the column.
Thanks, Bill
