26 Roadster Steering column
				Bill Coyle
- First Name: Bill
- Last Name: Coyle
On the 26/27 coupe, roadster, touring, and tudor, which side of the firewall should the steering column flange mount ?  I've looked over quite a few pics on the net and it seems both ways are quite common. I believe on the pre 26 models they all mounted to the inside (passenger side) of the firewall.
I'm thinking the 26/27 also mounts on the inside. As a side note, I've found earlier threads showing two styles of the bottom bracket. They are mounted on the outside (engine side) of the firewall.
Thanks, Bill
Thanks, Bill
Re: 26 Roadster Steering column
RE; I'm thinking the 26/27 also mounts on the inside. As a side note, I've found earlier threads showing two styles of the bottom bracket. They are mounted on the outside (engine side) of the firewall.
Correct, column on the inside bracket on the outside.
Brian D
- First Name: Brian
- Last Name: Dowell
- * REQUIRED* Type and Year of Model Ts owned: 14 Touring 26 Runnabout 19 Canadian Touring
Flange is on the inside. 26/27 flange is round.
Life is Good, be nice.
On our Canadian sourced cars, the 26-7 flange is square. It is an east way to distinguish them from earlier columns, especially when looking for a set of 5:1 components.
Roffe
- First Name: Rolf
- Last Name: Oehman
I agree with Allan. I think square flange is correct for the 1926-27 roadsters. At least it is on mine. Flange on the inside and brackets on the engine side of the firewall.
Roffe
- First Name: Rolf
- Last Name: Oehman
Looking closely at the photos it looks lik there is a bracket on both sides of the firewall.
- Last Name: Humble
Bill, 26-27 steering column flange is square, mounts to the inside of the firewall. The spacer bracket mounts on the outside of the firewall. There is also a picture in the Ford Service Manual Fig 563, not very clear in the new reprint manuals but does show up clearly in the original hard cover manual.
And...two styles of the steering gear to dash covers for '26-'27, the Fordor is unique.
The steering column mounts inside. The dash cover mounts outside the dash/firewall, that way the 2 upper holes in the steering column square flange line-up to the dash cover, that provides the lower 2 holes for the steering column square flange. And the dash cover lower edge holds the floorboard.
The best way is always the simplest. The attics of the world are cluttered up with complicated failures.     Henry Ford
				Bill Coyle
- First Name: Bill
- Last Name: Coyle
Thank you for the help and quick response!!  I changed out the original one because it was loose where the gear case is pinned to the column.  When I'd turn the steering wheel the gear case would rotate opposite a half inch.
I had the replacement one on the inside, but saw markings on it indicating it was mounted previously on the outside... so I changed it. Guess I'm moving it back to the inside today where it should be. My friend told me Any job worth doing is usually done twice!!
....sometimes more!!
Bill
Bill
				dmdeaton
- First Name: Danny
- Last Name: Deaton
Mine is square and I just finished installing it for the third time
I had mine on the outside and things didn’t go right with the bracket on the lower two holes. So I pull it out and get it all in there nice and pretty like. I was proud of myself until I tried to bolt the dash in place. What was in my way but the steering column. I am good at it now if you need a hand.
				dmdeaton
- First Name: Danny
- Last Name: Deaton
I am missing the bracket that supports the column to the dash. I didn’t see anything the vendors offer for this. Is this a bracket I need to beg for here on the forum? Mine is 26/27 also
I have one if their out of stock   https://www.modeltford.com/item/3500D.aspx
This steel brackets mounts onto the steel dash panel, just below the steering column and helps to support it.
It is a reproduction of the original bracket which is so hard to find and often missing.
Fits all 1926-1927 car bodies.
				dmdeaton
- First Name: Danny
- Last Name: Deaton
I will check
						I will check
				Bill Coyle
- First Name: Bill
- Last Name: Coyle
In and hooked up!  On the dash,  I remember reading about a padding that went between the column and the lower bracket. Does anyone use it?  I still have the original padding between the dash and the column.
Thanks, Bill
						Thanks, Bill
