Rear Axle Mystery Part
Redleg
Last Name: Neal
* REQUIRED* Type and Year of Model Ts owned: 1925 Roadster Pickup
Post by Redleg » Sun Mar 10, 2019 6:04 pm
T Teammates,
Can someone reveal the function of this modification on the rear axle?
Thanks,
John
John Neal
Virginia
‘25 Roadster Pickup
HaroldRJr
First Name: Harold
Last Name: Schwendeman
Re: Rear Axle Mystery Part
Post by HaroldRJr » Sun Mar 10, 2019 6:11 pm
.....an air vent to hopefully aid in the prevention of gear lube gradually leaking out thru' axle bearings due to rear end temperature change expansion.
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Sun Mar 10, 2019 6:19 pm
Looks like a homemade breather for an axle that has had modern seals installed.
With that hose barb, you could run some rubber hose to a location of your choice.
1924 Touring
John.Zibell
Last Name: Zibell
Post by John.Zibell » Sun Mar 10, 2019 6:20 pm
Yes, home made breather. I'd attach a long hose with a loop in it and attach the upper end up high to prevent water entering the rear end.
1926 Tudor
Redleg
Last Name: Neal
Post by Redleg » Sun Mar 10, 2019 9:26 pm
Thanks, gents.
John Neal
Virginia
‘25 Roadster Pickup
Post by Original Smith » Sun Mar 10, 2019 9:39 pm
Messed up a nice axle housing. The stupid things people do!
TFan
First Name: Jim
Last Name: Riedy
Post by TFan » Sun Mar 10, 2019 11:31 pm
Maybe it's for air pressure, hook a hose up to it and an air pump and pressurize to keep the oil up in the engine. :lol: Jim
Kaiser
First Name: Leo
Last Name: van Stirum
Post by Kaiser » Mon Mar 11, 2019 5:44 am
:D First T with Airride system fitted ? :lol:
Leo van Stirum, Netherlands
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Mon Mar 11, 2019 6:36 am
This was the first perpetual motion automobile. Hot air made by friction in the rear end was naturally pumped into the number four cylinder where the pressure added 30 miles to each gallon of gas used. The project was squelched when Henry found out the fitting would add 3 cents to the price of the Model T.....
George N Lake Ozark
First Name: George P
Last Name: Clipner
Post by George N Lake Ozark » Mon Mar 11, 2019 3:58 pm
My car came equipped with an oil fill cap.
