Rear Axle Mystery Part
Redleg
Topic author - Posts: 26
- Last Name: Neal
- * REQUIRED* Type and Year of Model Ts owned: 1925 Roadster Pickup
T Teammates,
Can someone reveal the function of this modification on the rear axle?
Thanks,
John
Thanks,
John
John Neal
Virginia
‘25 Roadster Pickup
Virginia
‘25 Roadster Pickup
HaroldRJr
- First Name: Harold
- Last Name: Schwendeman
Re: Rear Axle Mystery Part
.....an air vent to hopefully aid in the prevention of gear lube gradually leaking out thru' axle bearings due to rear end temperature change expansion.
RustyFords
- First Name: Don
- Last Name: Allen
Looks like a homemade breather for an axle that has had modern seals installed.
With that hose barb, you could run some rubber hose to a location of your choice.
1924 Touring
John.Zibell
- Last Name: Zibell
Yes, home made breather. I'd attach a long hose with a loop in it and attach the upper end up high to prevent water entering the rear end.
1926 Tudor
Messed up a nice axle housing. The stupid things people do!
TFan
- First Name: Jim
- Last Name: Riedy
Maybe it's for air pressure, hook a hose up to it and an air pump and pressurize to keep the oil up in the engine.
Jim
Kaiser
- First Name: Leo
- Last Name: van Stirum
Leo van Stirum, Netherlands
MichaelPawelek
- First Name: Michael
- Last Name: Pawelek
This was the first perpetual motion automobile. Hot air made by friction in the rear end was naturally pumped into the number four cylinder where the pressure added 30 miles to each gallon of gas used. The project was squelched when Henry found out the fitting would add 3 cents to the price of the Model T.....
George N Lake Ozark
- First Name: George P
- Last Name: Clipner
