Inner bearing sleeve
Belliott3
Topic author - Posts: 366
- First Name: Bill
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1916 Model T Touring
- Board Member Since: 2006
I have a question about my axle inner bearing sleeve; does it matter if the small button on the sleeve, that locks it into place, has been ground off? Otherwise, the sleeve is in great shape as are the other three but it just happens that someone ground off the locking button.
DickC
- First Name: Dick
- Last Name: Cruickshank
- * REQUIRED* Type and Year of Model Ts owned: 1912 Depot Hack, 1916 Touring
Re: Inner bearing sleeve
I would think not. It is there to keep it from turning.
Only reason to grind it off would be to use it on the incorrect side to align the grease hole !
- First Name: Jeff
- Last Name: Humble
The button is to keep it from spinning, so, yes, you need it. And there is no grease cup for the inner bearings.
Didn't catch that - thanks for the correction !
Les Schubert
- First Name: Les
- Last Name: Schubert
A spot of weld on the outside could easily fix it. You don’t need much
Nv Bob
- First Name: Bob
- Last Name: Middleton
Run it you'll be OK these have a spring to them and inner sleeves are well lined
Little tack weld would be ok but over kill in my opinion
Outer sleeve I just get one with dimple lot more stress and pressure on it
