Inner bearing sleeve
Belliott3
First Name: Bill
Last Name: Elliott
* REQUIRED* Type and Year of Model Ts owned: 1916 Model T Touring
Board Member Since: 2006
Post by Belliott3 » Sun Mar 10, 2019 1:23 pm
I have a question about my axle inner bearing sleeve; does it matter if the small button on the sleeve, that locks it into place, has been ground off? Otherwise, the sleeve is in great shape as are the other three but it just happens that someone ground off the locking button.
DickC
First Name: Dick
Last Name: Cruickshank
Re: Inner bearing sleeve
Post by DickC » Sun Mar 10, 2019 1:35 pm
I would think not. It is there to keep it from turning.
Post by RajoRacer » Sun Mar 10, 2019 1:39 pm
Only reason to grind it off would be to use it on the incorrect side to align the grease hole !
Last Name: Humble
Post by Humblej » Sun Mar 10, 2019 1:59 pm
The button is to keep it from spinning, so, yes, you need it. And there is no grease cup for the inner bearings.
Post by RajoRacer » Sun Mar 10, 2019 2:59 pm
Didn't catch that - thanks for the correction !
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sun Mar 10, 2019 3:44 pm
A spot of weld on the outside could easily fix it. You don’t need much
Nv Bob
First Name: Bob
Last Name: Middleton
Post by Nv Bob » Sun Mar 10, 2019 10:52 pm
Run it you'll be OK these have a spring to them and inner sleeves are well lined
Little tack weld would be ok but over kill in my opinion
Outer sleeve I just get one with dimple lot more stress and pressure on it
