Need a measurement for the rear spring mount
Reno Speedster
First Name: Morgan
Last Name: Blanchard
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T Speedster Project, 1922 Runabout Pickup
Post by Reno Speedster » Fri Oct 01, 2021 10:02 pm
I am working on a rear drop bracket for my speedster and I need to know the outside diameter of the rear spring mount (the one at the end of the axle). I want to be sure that the bracket will clear the spring when the suspension flexes. I don’t have one of the original mounts here to measure.
Could someone measure an original bracket for me?
Re: Need a measurement for the rear spring mount
Post by TRDxB2 » Sat Oct 02, 2021 1:23 am
I don't understand what to measure and on what year rear axle. Do mean the perch?
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Sun Oct 03, 2021 1:08 am
Apologies if I used the incorrect terminology. I am looking for the outside diameter of this part, where the shackle bolt bushing passes through. Based on the shackle and the spring, the part is 2” wide.
