Pinion Gears
oliverguy
Topic author - Posts: 17
- First Name: Bryan
- Last Name: Grube
- * REQUIRED* Type and Year of Model Ts owned: none at the moment
Pinion Gears
I'm trying to find a 13 tooth pinion gear for a Ruckstell rebuild. All the vendors seem to be running out of pinion gears. Does anybody know the story about what's going on with this? I was ok when the shortages were just about TP, but not this!
Re: Pinion Gears
Bryan, I took the 13 tooth pinion out of the Ruckstell on my speedster. As light as it was, and with a few upgrades to standard power, it remained seriously compromised in the braking department. It was far more safely drivable with the standard ratio. I had the 13/39 tooth gearset. I am not familiar with how a 13 tooth pinion can be mated to a standard 40 tooth crownwheel.
Kerry
- Last Name: van Ekeren
Re: Pinion Gears
I have 2, one is a good used one for the Ruckstell 40 tooth crown wheel and the other has been run, still like new, removed, the set was T-2518/24-HS 13x39
Postage from Australia isn't cheap
Dennis Fleming
- First Name: Dennis
- Last Name: Fleming
- * REQUIRED* Type and Year of Model Ts owned: 1913 touring,23 TT Express,23 Center Door,15 Touring,22 Speedster,22Coupe
Re: Pinion Gears
Bryan, I sent you an email about the 13 tooth I have listed on the classifieds parts.
oliverguy
- First Name: Bryan
- Last Name: Grube
Re: Pinion Gears
Hi Dennis, I'm interested. sent you a PM with my actual email address. For some reason I can't access these PM's. Do you take paypal or do you want me to send you a check?
Dennis Fleming
Re: Pinion Gears
Bryan I sent you a couple emails yesterday. Did you receive them?
oliverguy
- First Name: Bryan
- Last Name: Grube
Re: Pinion Gears
Thank you everyone for the responses! A pinion gear has been located.
