Overhead installation
Ralph F
First Name: Ralph
Last Name: Fitz-Gerald
Post by Ralph F » Tue Jan 25, 2022 11:12 am
I have an Roof Overhead that I what to install in 1920 roadster. I know need to cut the firewalls and I am looking for suggestions
Re: Overhead installation
Post by speedytinc » Tue Jan 25, 2022 11:39 am
Not necessarily.
I have a 20 touring with a rajo. The builder moved the BODY back 2" Hood extended. Hood shelves are wood. Steering frame mount back.
Fenders are not moved. Rear fenders are close to the doors, but fit. Subtle. Firewall uncut. I call it the monster. Frankenstein's monster.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Tue Jan 25, 2022 12:57 pm
Hank Lee posted some pictures in the past showing how he moved the existing firewall "hump" vertically and then added material below that to give clearance for a head. Perhaps he will repost those here. Obviously you loose your coil box, but....
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Tue Jan 25, 2022 1:08 pm
If you want to use an original coil box.., just dish more for the insulator(s) clearance! Been there done that!
Hank
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Jan 25, 2022 1:40 pm
I had no problems installing the Roof 8 ohv on my 26-7 4 door. Yes I had to install a flexible choke cable and adjusting the mixture was no longer possible from the dash. And yes it needs a fuel pump!
The 4 door of course has the fuel tank under the seat (the same as yours). A cowl mounted gas tank would likely be a problem, but I haven’t looked at it.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Jan 25, 2022 1:43 pm
You can see that the head really doesn’t extend past the rear head bolt!
Post by Rich Eagle » Tue Jan 25, 2022 2:12 pm
I made a wooden firewall for my Roof in my speedster and gave room for the cover to be removed.
P. S. Nice work Henry.
Post by Mark Gregush » Wed Jan 26, 2022 12:04 pm
Nice clean engine compartment, well laid out Rich!
22centerdoor
First Name: David
Last Name: Stauffacher
* REQUIRED* Type and Year of Model Ts owned: 1922 Centerdoor
Post by 22centerdoor » Fri Jan 28, 2022 12:58 am
I did the same as Hank. Had a local hot rod metal shop put recess in metal firewall. Looks really professional and almost "factory". I run a dizzy, so coils removed leaving more room for recess.
Dave
Ralph F
First Name: Ralph
Post by Ralph F » Mon Jan 31, 2022 12:16 pm
Gentleman thanks for the reply with good information. Now I have a few questions.
Richard what year ford did you make the wooden fire wall for?
Speedy I have learned that once changes dictates 10 more. Were there any changes to how the pedals and hand lever came thru the floor boards?
Henry the Roof Liberty Eight does extend behind the block and prevents the firewall from sitting down properly.
I would prefer not to cut the fire wall but that make be the route I take.
Thanks again
Ralph
Post by Rich Eagle » Mon Jan 31, 2022 12:38 pm
Ralph, my speedster is a 1920.
NoelChico
First Name: Noel
Last Name: Chicoine
Post by NoelChico » Mon Jan 31, 2022 2:21 pm
I'm contemplating installing a RAJO C-35 in my '26 coupe. I suspect I'll need to modify the firewall but wonder if I can "easily" run my coilbox and coils.
Kerry
Last Name: van Ekeren
Post by Kerry » Mon Jan 31, 2022 4:37 pm
Noel, not much room between the firewall and fuel tank, the Rajo rocker cover was modified to clear on the 26/7 fire wall. I removed my head as the cover dosen't seal up and stink of oil fumes.
Post by speedytinc » Tue Feb 01, 2022 8:29 am
Thanks again
Ralph
Floor board slots extended. Brake lever in stock position. Pedals are bent back about an inch, heated above the cams. "The Monster"
