1911 fire wall and fire wall support
AndreFordT
First Name: Andre
Last Name: Valkenaers
Post by AndreFordT » Fri Jan 28, 2022 1:27 pm
Hi all,
I am working on a 1911 Model T Torpedo.
Last week I ordered the right fire wall and finished the clear coat job.
I have questions about the fire wall supports. Are they different as the 1913 support?
In the fire wall, on the car they are three bolt to attach the support on the fire wall.
On the fire wall, I ordered, there are only two holes to fix the fire wall. The drawing shows the same.
Can some one post some good photos of the 1911 torpedo fire wall and the way it is attached to the body and the frame inside and outside?
Andre
Belgium
Fire wall plan.
Fire wall plan.
The fire wall on the car.
The new fire wall I get.
pete eastwood
First Name: Pete
Last Name: Eastwood
Re: 1911 fire wall and fire wall support
Post by pete eastwood » Fri Jan 28, 2022 2:59 pm
the 1911 " torpedo " has unique frame to firewall mounting brackets .
It has two mounting holes to the dash & it is offset 2 inches to the rear where it mounts to the frame,
as the torpedo hood is 2 inches longer .
pete eastwood
First Name: Pete
Last Name: Eastwood
Post by pete eastwood » Fri Jan 28, 2022 3:05 pm
these are Torpedo brackets
AndreFordT
First Name: Andre
Post by AndreFordT » Fri Jan 28, 2022 6:24 pm
Thanks Pete,
Do you have measurments for these brackets?
Andre
Belgium
ahovey
First Name: Austin
Last Name: Hovey
* REQUIRED* Type and Year of Model Ts owned: ‘11 Torpedo
Board Member Since: 2014
Post by ahovey » Fri Jan 28, 2022 7:24 pm
Sorry for the wacky orientation but this should help. These are the dimensions from a likely repro bracket I have. Email me if you need anything, good luck!
Toddman
First Name: Todd
Last Name: Manoff
* REQUIRED* Type and Year of Model Ts owned: 1911 Open Runabout, 1923 Speedster
Post by Toddman » Fri Jan 28, 2022 11:13 pm
I am looking for a pair of Torpedo fire wall brackets for my 1911 open runabout. If anyone has a pair fore sale please let me know.
Many Thanks !!
Toddmanoff@gmail.com
Toddman
First Name: Todd
Last Name: Manoff
Post by Toddman » Fri Jan 28, 2022 11:28 pm
Ahovey,
Thanks for posting the drawing .
Can you tell me the dimentions on the torpedo style brackets.
Vertical holes, center to center 5"
From bottom (frame side) to lower vertical hole center ?
Horizontal holes center to center ?
From bottom corner to center of first horizontal hole ?
Many thanks
Toddman
AndreFordT
First Name: Andre
Post by AndreFordT » Sat Jan 29, 2022 7:59 am
I just found brackets in Chaffins Garage catalog .
3640/41T Firewall to Frame bracket set Torpedo.
Send a mail for availability of the parts.
Andre
Belgium
DickC
First Name: Dick
Last Name: Cruickshank
Post by DickC » Sat Jan 29, 2022 8:12 am
This may not be important and incorrect. I noticed that the firewall is drilled for the steering column bracket. I have been told that the lower hole is offset only on 1913. It looks like the firewall is drilled that way. I will not feel bad if I am corrected!!! Dick C.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Sat Jan 29, 2022 8:43 pm
Austin-
Thanks for those dimensions.
What is the dimension from the flat back side to the center of the back hole?
What is the distance between the holes?
Thanks,
Keith
