Driveshaft bushing
CazeaultsModelTs
First Name: Albert
Last Name: Cazeault
* REQUIRED* Type and Year of Model Ts owned: 1917 Touring 1926 Roadster 1923 farm truck
Driveshaft bushing
Post by CazeaultsModelTs » Thu Mar 17, 2022 6:30 pm
I cannot get grease through the driveshaft bushing, is it a hole straight through the bushing or is it a channel that delivers it to multiple locations?
Re: Driveshaft bushing
Post by RajoRacer » Thu Mar 17, 2022 6:39 pm
Depends if it was installed correctly & either an original or a correctly made repro but yes, there is a grease galley.
Post by TRDxB2 » Thu Mar 17, 2022 7:25 pm
I believe the process : The bushing is to be inserted with the oil groves aligned with the oil hole in the torque tube then the hole is drilled an then the busing is reamed & faced.
CazeaultsModelTs
First Name: Albert
Last Name: Cazeault
Post by CazeaultsModelTs » Thu Mar 17, 2022 8:31 pm
It appears that once again this guy installed something incorrectly, the bushing is 180degrees off.
Dropacent
Last Name: Morsher
Post by Dropacent » Thu Mar 17, 2022 8:41 pm
It could have spun, too. The repro’s are sometimes a loose fit and need to be glued in.
Last Name: Juhl
Post by Oldav8tor » Thu Mar 17, 2022 9:18 pm
If you decide to remove it be careful. More than one guy has sheared off rivets trying to drive it from the far end of the tube. You want to use a puller designed for the purpose.
Post by RajoRacer » Thu Mar 17, 2022 9:36 pm
I just removed & replaced the same bushing that was installed incorrectly - they drilled the hole but it was opposite the grease slot.
CazeaultsModelTs
First Name: Albert
Last Name: Cazeault
Post by CazeaultsModelTs » Fri Mar 18, 2022 2:11 pm
It could have spun but everything this guy installed has been incorrect so far
Sean Butler
First Name: Sean
Last Name: Butler
Post by Sean Butler » Fri Mar 18, 2022 6:14 pm
You have to appreciate consistency... :(
Sean Butler
Huntington Beach, CA
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Fri Mar 18, 2022 6:46 pm
Considering how much oil most T’s leak by the ball cap I wouldn’t think it is a big deal. I haven’t greased that bushing in 45 years.
Post by TRDxB2 » Fri Mar 18, 2022 9:17 pm
I'm with you. But your suppose to put grease in the Ball Cap to lube the u-joint and oil to lube the drive shaft bushing. I think that theory was that the oil would dilute the grease seeping into the busing providing the intended consistency.
