Lifter guides
Topic author - Posts: 1151
- Last Name: Gould
Lifter guides
When the lifter guides are bored to the max and there is still too much play, what do you use to bring the bores back to standard or at least the first OS?
I've heard of using a flange bushing with the flange at the bottom pressed into a circle milled out under the guide. Should be an easier fix with just a thin steel bushing.
What do folks do?
What do folks do?
Re: Lifter guides
The lifter bores get bored out for replacement lifter guides presses in, just like valve guides.RGould1910 wrote: ↑Thu Apr 07, 2022 2:26 pmWhen the lifter guides are bored to the max and there is still too much play, what do you use to bring the bores back to standard or at least the first OS?
What do folks do?
Press fit is enough. Not familiar with special flanged bushings & counter bores. Guides should be cast iron, not steel.
- First Name: Pete
- Last Name: Eastwood
Re: Lifter guides
you could hard chrome the lifters oversize
Re: Lifter guides
You could bore to .500 & use .292/312 y block lifters. Thread them for an adjusting screw. One of my T's is running them now.
- First Name: Henry
- Last Name: Lee
Re: Lifter guides
There is plenty of side access if you wish to use a set screw for piece of mind. Just Sayin'
- First Name: Les
- Last Name: Schubert
Re: Lifter guides
Years ago I put model A lifters into a T block. Worked fine.
I am putting the Y block ones into a engine soon.
- First Name: Trent
- Last Name: Boggess
Re: Lifter guides
NOS Ford replacement T push rod guides look like this:
Respectfully submitted,
Trent Boggess
Trent Boggess
- Last Name: Gould
Re: Lifter guides
Great info and photos. Thanks.
Trent do you know if the lifter guides in the block are part of the block casting or are they separate pieces thar can be pressed out. If not then the block must be bored to accept the replacement guides, correct?
Much of my experience is with 09, 10 early 11 blocks with the removable guides.
- Last Name: Hatch
Re: Lifter guides
Part of casting, must be bored out.
Any machine shop that can install valve guides can install lifter guides. Should even have a modern guide to do the job. Dan
- First Name: ROBERT
- Last Name: BERGSTADT
Re: Lifter guides
I have some nos guides,Bob
- First Name: Trent
Re: Lifter guides
1909 to early 1911 open valve engines used replaceable brass push rod guides.
Trent Boggess
Trent Boggess
