What Goes Here?
BLB27
First Name: Bruce
Last Name: Brakke
What Goes Here?
Post by BLB27 » Wed Apr 27, 2022 8:06 pm
Does anyone have picture of what goes here? Is it worth removing the dash to replace It?
Alan Long
First Name: Alan
Last Name: Long
Re: What Goes Here?
Post by Alan Long » Wed Apr 27, 2022 8:18 pm
Are you referring to the Steering Column, Ampmeter / Ignition Switch, Speedo our Dash Light?
Alan In Western Australia
mtntee20
First Name: Terry & Sharon
Last Name: Miller
Re: What Goes Here?
Post by mtntee20 » Wed Apr 27, 2022 8:22 pm
Bruce,
I am not seeing what item/location you are asking about. I see a steering column, switch/ammeter, and speedometer with the dash light above it. Sorry, I must not be seeing the problem.
After taking a longer look, are you talking about the kick panel to the left of the driver's foot?
Re: What Goes Here?
Post by Norman Kling » Wed Apr 27, 2022 8:25 pm
I think all 26-27 Model T's have the gas tank under the cowl in front of the dash. Only the 4dor has it under the seat. The tank can be placed without removing the dash. All the switch and ammeter and light can be installed without moving it. I'm not sure about a speedometer.
Re: What Goes Here?
Post by Scott_Conger » Wed Apr 27, 2022 8:46 pm
That used to be windlass for the interior and those used to be original plated screws
Hopefully, the gas tank interior is spotlessly clean at this point.
BLB27
First Name: Bruce
Last Name: Brakke
Re: What Goes Here?
Post by BLB27 » Wed Apr 27, 2022 9:06 pm
Sorry that I was not clearer in my question!! I meant the fiber material between the dash and the door column.
Re: What Goes Here?
Post by Scott_Conger » Wed Apr 27, 2022 9:54 pm
windlace, not windlass
BLB27
First Name: Bruce
Last Name: Brakke
Re: What Goes Here?
Post by BLB27 » Wed Apr 27, 2022 10:23 pm
Scott, Here is several looks into the gas tank.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: What Goes Here?
Post by Kevin Pharis » Wed Apr 27, 2022 11:11 pm
Even tho the inside of the tank is spotless... be sure to inspect the external front panel of the tank for deep rust pits. There was a tar paper anti squeak pad between the tank and firewall that was notorious for holding water and causing rust.
Also, be careful not to tighten the mounting straps any tighter than necessary, as the solder joints will be stressed and develop cracks.
Alan Long
First Name: Alan
Last Name: Long
Re: What Goes Here?
Post by Alan Long » Thu Apr 28, 2022 4:02 am
If only my Fuel Tank was that clean! Consider yourself fortunate (or is it a result of thorough cleaning?)
mtntee20
Last Name: Miller
Re: What Goes Here?
Post by mtntee20 » Thu Apr 28, 2022 5:47 am
Hi Again,
I do not know what that fiber material was made out of originally. I believe it was just for looks and to reduce/prevent squeaking. If you need to replace it, a piece of an old leather belt should work. Otherwise, if it's in relatively good condition, I wouldn't mess with it unless I absolutely needed to. Let sleeping dogs lie.
Cheers
Re: What Goes Here?
Post by Scott_Conger » Thu Apr 28, 2022 12:01 pm
Or you could put windlace in it like what belongs there. There is nothing exotic about it, nor is it rare. If the correct interior is purchased, it should come with it.
If it was my car, I'd be removing all of the sheet metal parts around it, removing every bit of old interior, and replace things properly after painting.
BLB27
First Name: Bruce
Last Name: Brakke
Re: What Goes Here?
Post by BLB27 » Thu Apr 28, 2022 2:24 pm
Kevin, I was fortunate the back of the tank, which was up against the card board piece, was in good shape as shown in the attached photo.
Alan, I did not have to do any cleaning inside other than rinse it with gas and a little oil mixed in. I was surprise on the inside condition being that the tank had not been used in 62 years!
Jim Eubanks
First Name: Jim
Last Name: Eubanks
* REQUIRED* Type and Year of Model Ts owned: 1926 touring, 1927 cpe
Re: What Goes Here?
Post by Jim Eubanks » Thu Apr 28, 2022 5:19 pm
While your tank is out, check the best you can for loose baffles. 26/7 cars are bad for drumming noise made from loose tank baffles.
Re: What Goes Here?
Post by speedytinc » Thu Apr 28, 2022 5:23 pm
What do you do if they are loose? Whats the fix?
