Front Seat Back to Riser Assembly 1917-22
SurveyKing
First Name: Daniel
Last Name: Snell
* REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
Board Member Since: 2014
Post by SurveyKing » Mon May 02, 2022 7:18 pm
I am trying to figure how the front seat back attaches to the front seat riser on a 1917 thru 1922 Touring. There are nine holes that go thru bottom of the kick panel then through the bottom of the seat back. They then would hold the bottom tack strip. Could someone post a photo (or email me with one) that shows an original interior shot of the seat back to riser panel prior to the installation of the seat back cushion. I think they are the same for 1917 through 1922 maybe even through 1925. Any help here would be appreciated. Also like to know what bolts or screws were originally used here. Thanks in advance for any help.
Danielsnell2@twc.com
Re: Front Seat Back to Riser Assembly 1917-22
Post by John kuehn » Mon May 02, 2022 7:33 pm
17-22 T open cars were built by 5 different body makers. That can make trying to get it right a bit confusing. They are generally the same but not quite. I have a 21 Touring that I restored but didn’t take any pictures when I was putting it together and wish I would have. I did find a few other cars that showed what I needed to do when putting my car together. I did a general search on the net instead of going through the forum and found what I needed to know that way and it was faster. Hope this helps.
Post by John kuehn » Mon May 02, 2022 7:40 pm
Here is some information that may help you. http://www.mtfca.com/discus/messages/25 ... 1356213511
This post helped me a lot. Good luck!
Last Name: House
Post by George House » Mon May 02, 2022 7:56 pm
Daniel,... I don’t even know how to use the alleged search feature on the Forum but I always go to google to find my Model T info. In your case I googled “mtfca touring seat wood” and this is one of many pictures that appeared..🇺🇦
Post by John kuehn » Mon May 02, 2022 8:12 pm
Your right about that George. That’s how I find T information and it’s faster. The picture you posted is one of many and on the post I made reference to in my reply. And there are many more besides the one on the older post.
SurveyKing
First Name: Daniel
Last Name: Snell
Post by SurveyKing » Tue May 03, 2022 12:36 am
Thanks John and George, I shall do some research to see what I can find.
VowellArt
First Name: Martynn
Last Name: Vowell
Board Member Since: 2012
Post by VowellArt » Tue May 03, 2022 1:29 am
On a 17-22 the front should look like this (that picture looks more like a 15 or 16) the front seat didn't have one of those risers, but the back seat does. The seat back tack rail supports the seat back tin and anchors it to the body wood frame, through the armrests....the springs are tied to the top two seat back tack rail cleats. Now what my car did have on the inside of the seat back tin was a piece of roofing felt to keep the tinniness down...I replaced it with Jute felt.
My touring is an early 1922, with a 2 man top.
Front seat
Rear seat.
Fun never quits!
SurveyKing
First Name: Daniel
Last Name: Snell
Post by SurveyKing » Wed May 04, 2022 8:36 am
Marty, that is a nice looking Touring you have there and I also like the name of your beautiful state, "Commiefornia". I used to live there back in the 70's when it was still fairly sane, I could not imagine what it is like now. Anyway, what I am needing to know is how that front seat back attaches at the bottom to the front seat riser and kick panel. Here are some photos of my 21. I also seem to have quite a gap between the side seat rail and the rear kick panel. Isn't it supposed to be flush here?
Driver Side
Driver Side
Passenger Side
Passenger Side
Passenger Side
Passenger Side
