Wolf Whistle INSTALL PIC's?
Professor Fate
Last Name: S
* REQUIRED* Type and Year of Model Ts owned: '23 and '26
Post by Professor Fate » Thu Jun 02, 2022 12:18 am
Can you please post some pics of mounting/installation? Looking for ideas. Thanks!
________________
**FATE**
Re: Wolf Whistle INSTALL PIC's?
Post by TRDxB2 » Thu Jun 02, 2022 12:45 am
Instructions says its Attaches to any vacuum source on any engine.
Post by John kuehn » Thu Jun 02, 2022 1:42 pm
Some drill a hole on the side of the intake manifold. Then tap the hole to 1/8” pipe thread.
If I remember the instructions suggest doing it.
Whenever in doubt read the instructions.
Post by TXGOAT2 » Thu Jun 02, 2022 1:59 pm
The instructions are somewhat confusing. You can mount it anywhere near the engine that is convenient and that you can get a control wire, string, or cable to. Connecting it to the manifold near the center will allow you to control the pitch with both the control valve and the throttle. A foot throttle would be a good addition for using one of these on a Model T. A bracket could be made to attach the device to the radiator stay rod. ////// CAUTION!! If you operate this device around the wrong sort of person, you may need to hire Johnny Dep's lawyer. Not for use in Seattle or Berkeley.
PDGx
First Name: Paul
Last Name: Grohsmeyer
* REQUIRED* Type and Year of Model Ts owned: ‘17 TT Holmes Wrecker
Post by PDGx » Thu Jun 02, 2022 5:22 pm
This one is on our A, but same concept.
Wolf whistle A
Wolf whistle A
Professor Fate
Last Name: S
Post by Professor Fate » Thu Jun 02, 2022 7:41 pm
What is that circled piece that let's it turn 90degrees?
________________
**FATE**
Post by DanTreace » Fri Jun 03, 2022 10:57 am
This earlier thread has photo of install on T intake, just needs a pull wire to the driver’s position.
https://www.mtfca.com/discus/messages/7 ... 1498802200
Post by TXGOAT2 » Fri Jun 03, 2022 12:26 pm
Operating the device will lean out the mixture, and might kill the engine at idle. Richening the mixture adjustment momentarily would offset that. If you worked the throttle and and the control wire just right, you might get both a squawk from the whistle and a carburetor backfire.
PDGx
First Name: Paul
Post by PDGx » Sat Jun 04, 2022 11:42 am
Don’t know where that mount came from. Possibly a marine catalog. It just made the install look better I thought.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Sun Jun 05, 2022 1:11 pm
The part about not being legal in some states is true, but should say all states.
Post by TXGOAT2 » Sun Jun 05, 2022 3:27 pm
The USA is rapidly approaching MAX BAN, where everything will be illegal. (For US citizens)
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Sun Jun 05, 2022 7:34 pm
Brother Dave had a plan 60 year ago.
He said they should make everything legal, then there would not be any crime at all.
His plan did not sell!
Professor Fate
Last Name: S
Post by Professor Fate » Mon Jun 06, 2022 6:02 am
The burnt valve comments make me not want to install one. Not worth a $55 toy to trash a great running rebuild I have nearly $3k in.
________________
**FATE**
Post by TXGOAT2 » Mon Jun 06, 2022 8:49 am
Unless you operate the horn continuously, you won't harm your valves. Cars have used vacuum wipers motors and vacuum brake boosters for decades without issues. If you're working the horn a lot, temporarily richen your fuel mixture a little. Some older heavy duty floats and trailers used vacuum brakes. They could dump a lot of air into the engine intake when used heavily.
cslandry
First Name: Chris
Last Name: Landry
* REQUIRED* Type and Year of Model Ts owned: 1915 Speedster, 1926 Touring, 1923 Depot Hack project
Post by cslandry » Wed Jun 08, 2022 9:17 am
Post by Jerry VanOoteghem » Wed Jun 08, 2022 10:41 am
I wouldn't worry about that in the least! Just a bunch of overthinking, which this forum is excellent at. For the 2 seconds you operate it, you won't notice an ounce of trouble. (Well... you might get a rude look from some.)
Install your whistle, have fun!
Post by TXGOAT2 » Wed Jun 08, 2022 12:09 pm
I would suggest mounting the horn in such a way that it cannot collect water and dirt. Any water and debris that collects in the horn will cause trouble with the horn valve and could get into the engine.
Professor Fate
Last Name: S
Post by Professor Fate » Wed Jun 08, 2022 11:48 pm
I've kicked the idea of a whistle on the car down the road.... other, bigger things to focus on at the moment. Not a priority at this time. Thanks for pics and ideas.
________________
**FATE**
