Wolf Whistle INSTALL PIC's?
Professor Fate
Topic author - Posts: 773
- Last Name: S
Can you please post some pics of mounting/installation? Looking for ideas. Thanks!
- Attachments
- dowolfwwnload.jpeg (13.41 KiB) Viewed 5300 times
________________
**FATE**
**FATE**
Re: Wolf Whistle INSTALL PIC's?
Instructions says its Attaches to any vacuum source on any engine.Professor Fate wrote: ↑Thu Jun 02, 2022 12:18 amCan you please post some pics of mounting/installation? Looking for ideas. Thanks!
Some drill a hole on the side of the intake manifold. Then tap the hole to 1/8” pipe thread.
If I remember the instructions suggest doing it.
Whenever in doubt read the instructions.
The instructions are somewhat confusing. You can mount it anywhere near the engine that is convenient and that you can get a control wire, string, or cable to. Connecting it to the manifold near the center will allow you to control the pitch with both the control valve and the throttle. A foot throttle would be a good addition for using one of these on a Model T. A bracket could be made to attach the device to the radiator stay rod. ////// CAUTION!! If you operate this device around the wrong sort of person, you may need to hire Johnny Dep's lawyer. Not for use in Seattle or Berkeley.
PDGx
- First Name: Paul
- Last Name: Grohsmeyer
This one is on our A, but same concept.
Professor Fate
- Last Name: S
What is that circled piece that let's it turn 90degrees?
- Attachments
- 20220602_194058.png (83.19 KiB) Viewed 5074 times
________________
**FATE**
**FATE**
This earlier thread has photo of install on T intake, just needs a pull wire to the driver’s position.
https://www.mtfca.com/discus/messages/7 ... 1498802200
Operating the device will lean out the mixture, and might kill the engine at idle. Richening the mixture adjustment momentarily would offset that. If you worked the throttle and and the control wire just right, you might get both a squawk from the whistle and a carburetor backfire.
PDGx
- First Name: Paul
Don’t know where that mount came from. Possibly a marine catalog. It just made the install look better I thought.Professor Fate wrote: ↑Thu Jun 02, 2022 7:41 pmWhat is that circled piece that let's it turn 90degrees?
J1MGOLDEN
- Last Name: Golden
The part about not being legal in some states is true, but should say all states.
The USA is rapidly approaching MAX BAN, where everything will be illegal. (For US citizens)
J1MGOLDEN
- Last Name: Golden
Brother Dave had a plan 60 year ago.
He said they should make everything legal, then there would not be any crime at all.
His plan did not sell!
Professor Fate
- Last Name: S
The burnt valve comments make me not want to install one. Not worth a $55 toy to trash a great running rebuild I have nearly $3k in.
________________
**FATE**
**FATE**
Unless you operate the horn continuously, you won't harm your valves. Cars have used vacuum wipers motors and vacuum brake boosters for decades without issues. If you're working the horn a lot, temporarily richen your fuel mixture a little. Some older heavy duty floats and trailers used vacuum brakes. They could dump a lot of air into the engine intake when used heavily.
I wouldn't worry about that in the least! Just a bunch of overthinking, which this forum is excellent at. For the 2 seconds you operate it, you won't notice an ounce of trouble. (Well... you might get a rude look from some.)Professor Fate wrote: ↑Mon Jun 06, 2022 6:02 amThe burnt valve comments make me not want to install one. Not worth a $55 toy to trash a great running rebuild I have nearly $3k in.
Install your whistle, have fun!
I would suggest mounting the horn in such a way that it cannot collect water and dirt. Any water and debris that collects in the horn will cause trouble with the horn valve and could get into the engine.
Professor Fate
- Last Name: S
I've kicked the idea of a whistle on the car down the road.... other, bigger things to focus on at the moment. Not a priority at this time. Thanks for pics and ideas.
________________
**FATE**
**FATE**
