McDonough Model T Go Kart
Tourabout
First Name: Robbie
Last Name: Price
Post by Tourabout » Mon Sep 19, 2022 8:46 pm
I am looking for some parts for the McDonough T10 Go Kart. Is there a source for parts for these?
I am mainly looking for the 2 piece pulley for the motor shaft and the gear box pulley with the reverse disk mounted to it.
Thanks,
Robbie
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Re: McDonough Model T Go Kart
Post by ThreePedalTapDancer » Tue Sep 20, 2022 1:37 am
Post by TRDxB2 » Tue Sep 20, 2022 3:56 am
Questionable is they really have parts as advertised for the T10 https://gokartguru.com/model-t-go-kart-parts-store/ the web site last update ©2021 Gamble Industries LLC ~ All Rights Reserved not uncommon to be 1 year behind
Tourabout
First Name: Robbie
Last Name: Price
Post by Tourabout » Tue Sep 20, 2022 12:27 pm
No luck so far.
Anybody know which snapper mowers share some of the same parts?
Post by TRDxB2 » Tue Sep 20, 2022 2:26 pm
No luck so far.
I doubt if many members are familiar with the T 10 parts as you are, so you need to help with some dimensions. Do you have the parts to measure?
A replacement double belt pulley should be easy enough to find with the dimensions, OD, ID, key way size and belt size.
The gear box pulley with the reverse disk mounted to it is likely to be difficult - how is the revers disk attached? would a separate pulley work.
Found a picture of the reverse disk link shows instructions https://gokartguru.com/model-t-go-kart-reverser-disc/
Again that pulley should be able to be found
reverser disk.png (338.5 KiB) Viewed 3900 times
First Name: craig
Last Name: leach
Post by Craig Leach » Tue Sep 20, 2022 3:42 pm
Hi Robby,
Looks like you found the reverse pulley. the engine drive pulley should be something that a Bearing, belt & Chain dealer would have. The
model that used the Snapper parts was a different one that used a vertical shaft engine, belt tensioner clutch and a forward & reverse belt
to chain 90* shift box that was used in early riding mowers. The gear box in yours is from a washing machine.
Tourabout
First Name: Robbie
Last Name: Price
Post by Tourabout » Tue Sep 20, 2022 5:26 pm
The pulley on the engine has two grooves, the groove closest to the engine is cut so that the reverser disc will mesh inside it and cause it to turn in the opposite direction. The outer groove is adjustable and takes a 3/8” wide belt which drives the pulley the reverser disc is mounted to.
I found a pulley that is similar which I have included a picture of.
I also am including a diagram showing the parts. It’s not very clear but you get the idea. There are also part numbers listed.
Post by TRDxB2 » Tue Sep 20, 2022 6:17 pm
This pulley same as above
Scroll down this link for dimensions https://www.grainger.com/product/52YP81 ... lsrc=aw.ds
Size matters
Tourabout
First Name: Robbie
Last Name: Price
Post by Tourabout » Tue Sep 20, 2022 6:30 pm
I think this one is close but will have to get a measurement to be sure.
Last Name: Hatch
Post by Dan Hatch » Tue Sep 20, 2022 7:36 pm
I think you will find that both groves are adjustable on that Grainger pulley.
Tourabout
First Name: Robbie
Last Name: Price
Post by Tourabout » Tue Sep 20, 2022 9:29 pm
That could work especially for fitment of the reverse disc because it makes contact with the taper of the pulley.
The original pulley was 3” diameter and this one isn’t that far off especially with it being adjustable.
