Stevens Timing Tool
First Name: Adrian
Last Name: Whiteman
Stevens Timing Tool
Post by A Whiteman » Wed Feb 01, 2023 4:10 pm
Has anyone seem one of these or have them in their collections?
It looks useful, but did it actually work? I would think NOT to use this when the engine is running as the little ball would be a blur to see I guess.
But could be a bonus when turning over slowly as that would show both TDC and spark firing in one tool.
BUSHMIKE
Last Name: Cushway
* REQUIRED* Type and Year of Model Ts owned: 1925 TT, 1926 TT, 1926 TT
Re: Stevens Timing Tool
Post by BUSHMIKE » Wed Feb 01, 2023 4:23 pm
Cool tool! It almost had to utilize a piston against a spring calibrated to a new compression pressure. Weak rings or leaky valves and I doubt it worked as intended. Nevertheless a neat idea.
Post by Rich Eagle » Wed Feb 01, 2023 4:28 pm
Steven King posted this nice picture of one a few years ago.
http://www.mtfca.com/discus/messages/82 ... 1531292223
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Wed Feb 01, 2023 5:05 pm
They are for moving the crank slowly by hand to find TDC and timing.
dobro1956
First Name: Donnie
Last Name: Brown
Post by dobro1956 » Wed Feb 01, 2023 7:09 pm
I have one, but never tried to use it.
Post by Steve Jelf » Wed Feb 01, 2023 10:37 pm
There have been several fancy doodads to set timing over the past 100 years. Currently Lang's sells one that even lights up (for $87). They are all less accurate than going by the pin position, which has the advantage of costing the perfect price — nothing. https://dauntlessgeezer.com/DG97.html
