Has anyone seem one of these or have them in their collections?
It looks useful, but did it actually work? I would think NOT to use this when the engine is running as the little ball would be a blur to see I guess.
But could be a bonus when turning over slowly as that would show both TDC and spark firing in one tool.
Stevens Timing Tool
Topic author - Posts: 1201
- First Name: Adrian
- Last Name: Whiteman
BUSHMIKE
- First Name: Mike
- Last Name: Cushway
- * REQUIRED* Type and Year of Model Ts owned: 1925 TT, 1926 TT, 1926 TT
Re: Stevens Timing Tool
Cool tool! It almost had to utilize a piston against a spring calibrated to a new compression pressure. Weak rings or leaky valves and I doubt it worked as intended. Nevertheless a neat idea.
Steven King posted this nice picture of one a few years ago.
http://www.mtfca.com/discus/messages/82 ... 1531292223
- Last Name: Humble
They are for moving the crank slowly by hand to find TDC and timing.
dobro1956
- First Name: Donnie
- Last Name: Brown
I have one, but never tried to use it.
There have been several fancy doodads to set timing over the past 100 years. Currently Lang's sells one that even lights up (for $87). They are all less accurate than going by the pin position, which has the advantage of costing the perfect price — nothing. https://dauntlessgeezer.com/DG97.html
