Ruckstell Question
Plankhill
First Name: Brendan
Last Name: Doughty
* REQUIRED* Type and Year of Model Ts owned: 16 , 21, 24, Touring , 24 Roadster, 26 Speedster
Ruckstell Question
Post by Plankhill » Tue Mar 07, 2023 2:59 pm
Is the P139 thrust plate interchangeable between the Hal Scott and the Ruchstell? The Hall Scott internal gear is shorter than the Ruckstell.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: Ruckstell Question
Post by Dan McEachern » Tue Mar 07, 2023 9:41 pm
That's a question for Richard Gould.
Last Name: Tannehill
Post by JTT3 » Tue Mar 07, 2023 10:38 pm
Dan didn’t you post a picture one time with a scoop on the P159 ring gear support housing that you added for better internal lubrication? Was it brazed on or pinned? Best John
Post by Original Smith » Wed Mar 08, 2023 11:04 am
All passenger car parts are interchangeable, whether Hall Scott or Eaton.
RGould1910
Last Name: Gould
Post by RGould1910 » Wed Mar 08, 2023 11:33 am
The only piece interchangeable between a Ruckstell and Perfecto is the large ball bearing.
