Wha’ happened?
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Wha’ happened?
Post by Charlie B in N.J. » Mon Apr 10, 2023 5:44 pm
Just curious. What happened the last few days. Forum was locked.
Dennis Prince
Last Name: Prince
Re: Wha’ happened?
Post by Dennis Prince » Mon Apr 10, 2023 5:53 pm
It has been working fine on the left coast. Well at my house any way.
Last Name: House
Re: Wha’ happened?
Post by George House » Mon Apr 10, 2023 5:56 pm
Worked well down here in so. central God’s country Texas😎🤔
Re: Wha’ happened?
Post by Wayne Sheldon » Mon Apr 10, 2023 8:22 pm
They had some major downtime a few weeks ago? Some sort of glitch in a system upgrade. But it has been fine at my place for a couple weeks now.
(Actual timelines subject to greater error as I get older?)
Re: Wha’ happened?
Post by TRDxB2 » Mon Apr 10, 2023 9:04 pm
You need to explain what you mean by "locked". Browsers prefer a website to be "locked" meaning it is secured. The "s" suffix on the end of https:// is an indication that the web site is secure with the LOCK ICON. This good and does not prevent access to the site
Just http:// could have a virus looming or not so browsers are starting to restrict access to those
If you felt "locked out" , that is not being able to access the FORUM then further information is needed. Where you using a smart phone or computer?
Sometimes an Internet Provider may be over protective , do you have a VPN. A VPN is an external Firewall in addition to your own that provides a higher level of security to sites
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Re: Wha’ happened?
Post by Charlie B in N.J. » Mon Apr 10, 2023 9:12 pm
Locked as in it wouldn’t up date from a few days ago. Hit the page refresher and nothing changed. From I believe Thursday. Never happened before.
Re: Wha’ happened?
Post by TRDxB2 » Mon Apr 10, 2023 9:41 pm
Still lots of possibilities - was this the only site with the problem
maybe you can figure it out https://www.google.com/search?client=fi ... 7t+refresh
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Re: Wha’ happened?
Post by Charlie B in N.J. » Wed Apr 12, 2023 7:56 pm
Happened again but at least I know what it is. The page won’t refresh keeps staying with the same dates and questions on it. The way around is to go to the main page and back to the Forum. Very odd.
Re: Wha’ happened?
Post by Scott_Conger » Wed Apr 12, 2023 8:05 pm
It sounds like a memory problem or cache problem and if it is, simply hitting "F5" or "CTRL-F5" will load the latest version of the page.
Re: Wha’ happened?
Post by TRDxB2 » Thu Apr 13, 2023 12:21 am
What brand computer, operating system & browser are you using?
Trying to understand
What "page" are you referring to. By that I mean like the list of discussion on the GENERAL DISCUSSION PAGE
Why are you expecting a change to that page when you do a refresh?
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Re: Wha’ happened?
Post by Charlie B in N.J. » Thu Apr 13, 2023 7:20 pm
iPad. General discussion page. Expecting a change when refreshing because it always worked. Didn’t work for 3 days.
Re: Wha’ happened?
Post by TRDxB2 » Thu Apr 13, 2023 9:35 pm
I don't use an iPad so... but my wife has one. I'll have to see how she uses it. But its impossible to repeat your situation.
Searching the web for answers https://www.google.com/search?q=ipad+sc ... -serp#ip=1
There is confusion in how the respondent interpreted "refresh" vs "update". An "update" discussion are related to app updates nit screen refresh. but suggest you look at some to see if any makes sense.
In one response talked about the screen not refreshing during an update. Also, is this the only web page with the problem?
