John Reagan - technical library
Topic author - Posts: 72
- First Name: Steven
- Last Name: Boothroyd
- * REQUIRED* Type and Year of Model Ts owned: US built 1922 touring
Does anyone know what happened to John Reagans technical library?
I've been out of the loop for quite a while.
Regards,
Steve Boothroyd
Regards,
Steve Boothroyd
- Last Name: Hjortnaes
Re: John Reagan - technical library
Try John Regan, not Reagan.
Not sure how long you have been "out of the loop". But in 2018 Birdhaven bought FunProjects and the FunProjects site expired a short time later. Birdhaven recently bought the new inventory & machinery from Bob's Antique Auto Parts in Rockford Il (Bob is still in business selling original parts).SteveBoothroyd wrote: ↑Thu Apr 13, 2023 4:32 pmDoes anyone know what happened to John Reagans technical library?
Regards,
Steve Boothroyd
Thankfully someone created a WEBPAGE to save old webpages https://web.archive.org/web/20201203202 ... jects.com/
Unfortunately they don't connect all the links. But its best to capture the source data and save in t he forum. Perhaps we can add to a forum page like Vowel art I'm going to download all the files, 50+, (PDF's) Techinfo and Instructions. I
Here are some
Some more..........................................
- Attachments
- Excessive Crankshaft Endplay Repair.pdf
- (683.51 KiB) Downloaded 130 times
- Model T Frame (early).pdf
- (36.37 KiB) Downloaded 96 times
- Installation Instructions Model - HSBCK1.pdf
- (16.02 KiB) Downloaded 86 times
- Model t ignition system-final artiticle.pdf
- (388.82 KiB) Downloaded 98 times
- More on Spark Timing.pdf
- (1023.86 KiB) Downloaded 99 times
- Attachments
- Brass Magneto Post (1909-1917) 3260.PDF
- (25.08 KiB) Downloaded 96 times
- Dash Shield (1909-1923) & Guide (1909-1912).PDF
- (17.38 KiB) Downloaded 116 times
- Fanbelt tension Spring (1909-1910) 3965.PDF
- (9.97 KiB) Downloaded 73 times
- Running Board Truss Rod - 4816.PDF
- (15.66 KiB) Downloaded 101 times
- Instructions -Strobe Spark- Coil Tester CT-1 (60Hz Version).pdf
- (602.01 KiB) Downloaded 97 times
- Attachments
- Installation Instructions 5055R-6V S5055R-6V.pdf
- (42.53 KiB) Downloaded 98 times
- Installation Intructions 5055R-8V S5055R-8V.PDF
- (53.32 KiB) Downloaded 68 times
- Installation Instructions 5055R-12V S5055R-12V.pdf
- (42.66 KiB) Downloaded 74 times
- Installation Instructions Voltmeter 5016-6V.pdf
- (34.54 KiB) Downloaded 75 times
- Installation Instructions Voltmeter 5016-12V.pdf
- (34.52 KiB) Downloaded 76 times
- Attachments
- Instructions Model 5007KW Clocks.pdf
- (16.32 KiB) Downloaded 90 times
- Installation Instructions Models 3260E1, 3260E2, 3260E3.PDF
- (36.57 KiB) Downloaded 77 times
- Installation Instructions Adjustable Bearing Spool Models - 2587-ADJ, 2587E1-ADJ.PDF
- (125.18 KiB) Downloaded 87 times
- Installation Instructions Adjustable Bearing Spool Models - 2587, 2587E1.PDF
- (51.83 KiB) Downloaded 86 times
- T5426 Dash Molding.pdf
- (29.2 KiB) Downloaded 89 times
- Attachments
- Floor Plan Trim Plates (1909-1917) 3630.PDF
- (11.81 KiB) Downloaded 89 times
- Lamp Bracket on Dash(1909-1914) 3655.PDF
- (10.75 KiB) Downloaded 75 times
- Instructions Model CT-2 Coil Beeper.pdf
- (16.42 KiB) Downloaded 78 times
- Instructions - Coil Units and Magneto Test Stand - FORD Manual.pdf
- (2.91 MiB) Downloaded 85 times
- Installation Instructions Model T12CK1.PDF
- (48.3 KiB) Downloaded 76 times
- Attachments
- Motorst-90110.pdf
- (38 KiB) Downloaded 76 times
- Accurate Spark Timing.pdf
- (742.74 KiB) Downloaded 116 times
- Installation Instructions Battery Horn 6V- Models 6432, 6432E2.PDF
- (38.97 KiB) Downloaded 83 times
- Installation Instructions Battery Horn 12V- Models 6432-12V, 6432E2-12V.PDF
- (38.99 KiB) Downloaded 69 times
- Installation Instructions rewood Models 5000-5001RK.pdf
- (128.28 KiB) Downloaded 86 times
Model A Voltage Regulators
- Attachments
- Instructions Model A Voltgae Regulator 6V NegGrnd & 12V Battery 10505RN12.pdf
- (24.39 KiB) Downloaded 76 times
- Instructions Model A Voltage Regulator 6V PosGrnd Models 10505R, S1050R.pdf
- (24.18 KiB) Downloaded 67 times
- Instructions Model A Voltage Regulator 6V PosGrnd & 12V battery Model 10505R12.pdf
- (24.15 KiB) Downloaded 59 times
- Instructions Model A Voltage Regulator 6V PosGrnd & 8V Battery Model 10505R8.pdf
- (24.08 KiB) Downloaded 71 times
Model A V8 Voltage Regulators
Ford 9N Tractor Voltage Regulators
--Ford 9N Tractor Voltage Regulators
- Last Name: Golden
John had a very good long term friend, Ron Patterson, that still rebuilds coils.
Until recent years, they were always together at Hershey and other events, like large swap meets.
Ron had a rather extensive library and downsized when he moved to a new location.
Ron donated all his library to the MTFCA Museum in Richmond, Indiana and they are available for research there.
I talked with Ron recently and he said he had not heard from John for some time now.
Ron does wish that John would call him again and catch up on life and other new activities.
This great information should be a permanent part of the MTFCA resources page. There are also others who have gathered lots of T information that’s really useful.
Maybe the resources page could have these as contributors.
I would add the Cimorelli Model T library.
- First Name: Darel
- Last Name: Leipold
WOW lots of very importanr information. I may download all and put on disc or tumb drive.
It would sure benefit the older T members and greatly benefit the younger. It makes good sense to me. At the very least the website addresses could be listed all in one place. Wow that seems simple.
Thanks everyone for your input; I really appreciate the information John created for the hobby.
Regards,
Steve Boothroyd
Sidney, B.C.
Canada
Regards,
Steve Boothroyd
Sidney, B.C.
Canada
- First Name: steven
- Last Name: davidson
- * REQUIRED* Type and Year of Model Ts owned: 1924 touring
Thanks for the links. I need to build that wheel press. I just sent the PDF to my office manager to print for me, and he just came back with full size roll up prints! I'll be able to hang it on the wall while I build it!
- First Name: Mack
- Last Name: Cole
It would seem the Museum would preserve these files or perhaps store them on site here for all to use?
I wish they could preserve all of Vince Iacinno's video's too.
- First Name: Gene
- Last Name: Carrothers
Ya, Those videos that Vince made were priceless when I installed one of his tops. I do have a set just ion case anyone reads this and is planning an upholstery job
1912 Torpedo Roadster
I do have a set just in case anyone reads this and is planning an upholstery job.
Take good care of them. When I inquired a few years ago all the copies had been sold and the masters were lost.
I have some of those copies. His wife still has the masters. No one wants to purchase them from her.
- Last Name: Suarez
I will download these files as well. Thank you. I remembered that I had already been advised to use this technical library but had forgotten about it. I need assignment help for a technical project, and it looks like I will be able to find a lot of useful info here. I'm also going to use this online source https://essays.edubirdie.com/assignment-help to secure a written part of my project and get a good result. Now I'm going to explore John Reagan library more.
