Anyone running LED Headlights?
Topic author - Posts: 322
- First Name: Ronald
- Last Name: Bakow
- * REQUIRED* Type and Year of Model Ts owned: 1915 Model T Touring
So is anyone running LED Headlights? If so can you give the model information and a little review for us guys without them?
Ron
Ron
- Last Name: Tannehill
Re: Anyone running LED Headlights?
Mine on a 25 pickup are great. I use 6 volt duals.
https://www.ledlight.com/searchresult.a ... gsc.page=1
viewtopic.php?f=2&t=6046&p=49258&hilit= ... HTS#p49258
- Last Name: Barker
- * REQUIRED* Type and Year of Model Ts owned: 1919 Speedster
I'm running them on my 1919 racer; both headlights and the tailight. Put them in last August. All good.
Here's a link to the ones I got. A little pricey, but I like being seen when necessary:
https://www.logolites.com/products/led- ... eadlights/
- Last Name: Hunter
- Board Member Since: 2002
I've been using them for about the last seven years. Very happy with their performance. The ones I'm using are 6V with high and low beam. They were obtained from http://www.classicandvintagebulbs.com/
I also replaced the reflectors which probably made more of a noticeable difference than changing to LED bulbs alone.
- First Name: craig
- Last Name: leach
I'm one of those darn 12 Volt people and have good reflectors so my lights are very good, but the first bulb that burns out I'm going to LED's
they are far suppirior to the regular ones.
- Last Name: Juhl
I run 12 volt LED Headlights, tail lights, side lights. Very happy with all. My headlights are single beam and give plenty of illumination for the speeds I drive.
- First Name: Keith
- Last Name: Townsend
None of my cars have generators. I rewired for LED bulbs to run off the battery, now I have constant brilliant light while drawing a fraction of an Amp.
I love 'em!
I love 'em!
- Last Name: Juhl
To build on what Keith wrote - I don't have a generator either. My Odyssey battery rides under the back seat and is kept charged by a John Regan Hot Shot charger that uses the magneto to charge the battery (AC to pulsating DC.) The LED's don't draw much current and the Hot Shot keeps the battery fully charged.
