Anyone running LED Headlights?
Model T Ron
First Name: Ronald
Last Name: Bakow
* REQUIRED* Type and Year of Model Ts owned: 1915 Model T Touring
Post by Model T Ron » Thu May 04, 2023 10:07 pm
So is anyone running LED Headlights? If so can you give the model information and a little review for us guys without them?
Ron
Last Name: Tannehill
Board Member Since: 2002
Re: Anyone running LED Headlights?
Post by JTT3 » Thu May 04, 2023 10:24 pm
DaveBarker
Last Name: Barker
Post by DaveBarker » Thu May 04, 2023 11:08 pm
I'm running them on my 1919 racer; both headlights and the tailight. Put them in last August. All good.
Here's a link to the ones I got. A little pricey, but I like being seen when necessary:
https://www.logolites.com/products/led- ... eadlights/
JohnH
Last Name: Hunter
Post by JohnH » Fri May 05, 2023 2:48 am
I've been using them for about the last seven years. Very happy with their performance. The ones I'm using are 6V with high and low beam. They were obtained from http://www.classicandvintagebulbs.com/
I also replaced the reflectors which probably made more of a noticeable difference than changing to LED bulbs alone.
First Name: craig
Last Name: leach
Post by Craig Leach » Fri May 05, 2023 3:07 am
I'm one of those darn 12 Volt people and have good reflectors so my lights are very good, but the first bulb that burns out I'm going to LED's
they are far suppirior to the regular ones.
Last Name: Juhl
Post by Oldav8tor » Fri May 05, 2023 10:10 am
I run 12 volt LED Headlights, tail lights, side lights. Very happy with all. My headlights are single beam and give plenty of illumination for the speeds I drive.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Fri May 05, 2023 10:46 am
None of my cars have generators. I rewired for LED bulbs to run off the battery, now I have constant brilliant light while drawing a fraction of an Amp.
I love 'em!
Last Name: Juhl
Post by Oldav8tor » Fri May 05, 2023 6:35 pm
To build on what Keith wrote - I don't have a generator either. My Odyssey battery rides under the back seat and is kept charged by a John Regan Hot Shot charger that uses the magneto to charge the battery (AC to pulsating DC.) The LED's don't draw much current and the Hot Shot keeps the battery fully charged.
