Ruxstell Grease
frontyboy
First Name: dick
Last Name: dock
* REQUIRED* Type and Year of Model Ts owned: T sprint cars
Ruxstell Grease
Post by frontyboy » Wed May 10, 2023 7:04 pm
What is used for Ruxstell lubrication these days. What is the modern equivalent viscosity and part number?
thnx
frontyboy
Re: Ruxstell Grease
Post by speedytinc » Wed May 10, 2023 7:11 pm
90 wt straight.
Re: Ruxstell Grease
Post by Original Smith » Thu May 11, 2023 11:25 am
First of all, Ruckstells don't use grease! I use straight SAE 140 wt.oil. I suppose a multigrade would be ok too, but haven't tried it.
Barteldes
First Name: Bill
Last Name: Barteldes
* REQUIRED* Type and Year of Model Ts owned: 1924 Coup
Re: Ruxstell Grease
Post by Barteldes » Thu May 11, 2023 5:56 pm
Is a ruxstell hard to install?
BIll B
No matter how you shake and dance the last few drops go down your pants.
Kerry
Last Name: van Ekeren
Re: Ruxstell Grease
Post by Kerry » Thu May 11, 2023 7:03 pm
You would think by the end run of T's when Ford approved of the Ruckstell that there would be a recommended lube for it. But period literature that I can find, only lists for T's and TT's a semi fluid oil Mobiloil C which I believe is 600w and what the vendors sell, by todays grading.
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Re: Ruxstell Grease
Post by MichaelPawelek » Thu May 11, 2023 9:27 pm
How much experience do you have working on older cars? Buy the Ruckstell rebuild manual and then make your decision.
frontyboy
First Name: dick
Last Name: dock
Re: Ruxstell Grease
Post by frontyboy » Thu May 11, 2023 11:48 pm
A very experienced Ruxstel restorer called me and mentioned that the old thick 600wt will cause galling and seize the planetary gear pins. He drills holes in them to give lubrication a better lubrication. So I'm going to use the 140wt gear lube.
I really appreciate the help thnx,
just sayin'
brasscarguy
Re: Ruxstell Grease
Post by speedytinc » Fri May 12, 2023 8:19 am
According to the rux build book: 140 for the standard rear axle & 90 wt for the rux. I think the 600 & 140 are too thick to get in & lube a rux.
Anyway, I have followed this recommendation for scores of services & axle builds. No issues yet.
YellowTRacer
First Name: Ed
Last Name: Archer
Board Member Since: 2009
Re: Ruxstell Grease
Post by YellowTRacer » Fri May 12, 2023 4:31 pm
Always a load of opinions here, so a load of options. Might as well submit mine. Been running 90 (maybe 90 only for the first few years) or 140 for at least 40 years and 600 for the last 27 or so years. Lots of miles, no Ruckstell problems.
Ed aka #4
