Ruxstell Grease
Topic author - Posts: 389
- First Name: dick
- Last Name: dock
- * REQUIRED* Type and Year of Model Ts owned: T sprint cars
Ruxstell Grease
What is used for Ruxstell lubrication these days. What is the modern equivalent viscosity and part number?
thnx
frontyboy
thnx
frontyboy
Re: Ruxstell Grease
90 wt straight.
Re: Ruxstell Grease
First of all, Ruckstells don't use grease! I use straight SAE 140 wt.oil. I suppose a multigrade would be ok too, but haven't tried it.
- First Name: Bill
- Last Name: Barteldes
- * REQUIRED* Type and Year of Model Ts owned: 1924 Coup
Re: Ruxstell Grease
Is a ruxstell hard to install?
BIll B
No matter how you shake and dance the last few drops go down your pants.
- Last Name: van Ekeren
Re: Ruxstell Grease
You would think by the end run of T's when Ford approved of the Ruckstell that there would be a recommended lube for it. But period literature that I can find, only lists for T's and TT's a semi fluid oil Mobiloil C which I believe is 600w and what the vendors sell, by todays grading.
- First Name: Michael
- Last Name: Pawelek
- First Name: dick
- Last Name: dock
Re: Ruxstell Grease
A very experienced Ruxstel restorer called me and mentioned that the old thick 600wt will cause galling and seize the planetary gear pins. He drills holes in them to give lubrication a better lubrication. So I'm going to use the 140wt gear lube.
I really appreciate the help thnx,
just sayin'
brasscarguy
just sayin'
brasscarguy
Re: Ruxstell Grease
According to the rux build book: 140 for the standard rear axle & 90 wt for the rux. I think the 600 & 140 are too thick to get in & lube a rux.
Anyway, I have followed this recommendation for scores of services & axle builds. No issues yet.
- First Name: Ed
- Last Name: Archer
- * REQUIRED* Type and Year of Model Ts owned: 1909 replica Transcontinental race car, 1915 2 man race car, 1918 American bodied speedster
- Board Member Since: 2009
Re: Ruxstell Grease
Always a load of opinions here, so a load of options. Might as well submit mine. Been running 90 (maybe 90 only for the first few years) or 140 for at least 40 years and 600 for the last 27 or so years. Lots of miles, no Ruckstell problems.
Ed aka #4
Ed aka #4
