T electric horn wiring
Bruce Compton
First Name: Bruce
Last Name: Compton
* REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
Post by Bruce Compton » Fri Jun 09, 2023 5:42 pm
Does anyone have a diagram of the wiring inside the T horn. The one I have has had the wiring removed and the contact plate is just hanging in mid-air. Thanks in advance; Bruce
varmint
First Name: Vernon
Last Name: Worley
Re: T electric horn wiring
Post by varmint » Fri Jun 09, 2023 6:21 pm
I might have some photos of the inside but you need to specify whether you have a magneto horn or battery horn. A make, year, and model# of the horn will probably help too.
Vern (Vieux Carre)
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Fri Jun 09, 2023 6:28 pm
app.php/gallery/image/2257
...if you have a magneto.
Vern (Vieux Carre)
Bruce Compton
First Name: Bruce
Last Name: Compton
Post by Bruce Compton » Fri Jun 09, 2023 6:53 pm
Thanks Vernon but I have the later 6 VDC electric horn.
Post by TRDxB2 » Fri Jun 09, 2023 8:24 pm
A picture of the horn internals would help.
Some 6v DC horns have one lead for the positive connection and the horn shell needs to be grounded.
If it has two posts for connection shouldn't matter which is + or - just which way sounds better
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Post by BE_ZERO_BE » Fri Jun 09, 2023 11:20 pm
Here are some links to color Wiring Schematics and Wire Harness Diagrams.
Wiring Schematics
https://nebula.wsimg.com/3e10aca08d1115 ... oworigin=1
Wiring Harness Diagrams
https://nebula.wsimg.com/3a0733937917a1 ... oworigin=1
Respectfully Submitted,
Be_Zero_Be
