T electric horn wiring
Bruce Compton
Topic author - Posts: 670
- First Name: Bruce
- Last Name: Compton
- * REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
Does anyone have a diagram of the wiring inside the T horn. The one I have has had the wiring removed and the contact plate is just hanging in mid-air. Thanks in advance; Bruce
varmint
- First Name: Vernon
- Last Name: Worley
Re: T electric horn wiring
I might have some photos of the inside but you need to specify whether you have a magneto horn or battery horn. A make, year, and model# of the horn will probably help too.
Vern (Vieux Carre)
Bruce Compton
- First Name: Bruce
Thanks Vernon but I have the later 6 VDC electric horn.
A picture of the horn internals would help.
Some 6v DC horns have one lead for the positive connection and the horn shell needs to be grounded.
If it has two posts for connection shouldn't matter which is + or - just which way sounds better
BE_ZERO_BE
- First Name: BOB
- Last Name: CASCISA
Here are some links to color Wiring Schematics and Wire Harness Diagrams.
Wiring Schematics
https://nebula.wsimg.com/3e10aca08d1115 ... oworigin=1
Wiring Harness Diagrams
https://nebula.wsimg.com/3a0733937917a1 ... oworigin=1
Wiring Schematics
Respectfully Submitted,
Be_Zero_Be
Be_Zero_Be
