Timken front wheel bearings
Algonac27
Topic author - Posts: 49
- First Name: Dale
- Last Name: Williams
- * REQUIRED* Type and Year of Model Ts owned: 1910 Touring, 1913 Touring, 1920 Coupe & Touring
Would anyone have the Timken numbers for outer and inner front bearings.
- Last Name: Strange
Re: Timken
A Google search for "timken front wheel bearings mtfca" revealed this older thread:
http://www.mtfca.com/discus/messages/70 ... 1511123413
Jeepbone1
- First Name: Brad
- Last Name: Kirtner
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
Re: Timken
Here you go.
Brad
Brad
- Attachments
- C3FE4FFB-0A65-4096-AC7C-9F9CFA48D871.jpeg (70.08 KiB) Viewed 5178 times
Re: Timken
Rock auto usually has the best prices on those, IF they're in stock.
Algonac27
- First Name: Dale
Re: Timken
Thanks guys!!!
Re: Timken
It's been so long since I've heard from Rock Auto, but if my lame brain is correct, I"m STILL waiting for the inside left bearing...or maybe it was the right side, or even both! Ha ha. Point is, they're mostly unobtanium for some stupid reason.Steve Jelf wrote: ↑Fri Nov 25, 2022 10:34 pmRock auto usually has the best prices on those, IF they're in stock.
Re: Timken
Rock Auto prices & availability TIMKEN 09075 doesn't look it is available anywhere but some sites indicate end of this year or January 2023
Re: Timken
Tim, it's the outer bearing that is out of stock. I have right hand bearing on back order with Langs, and no indication of availability. They have the left ones.
- Last Name: Hjortnaes
Re: Timken
Rock Auto will notify you when 9075 is available. However, they have had to renew my request 2-3X because my request has been in their system so long. If I hear anything I will post it on here, but dont hold your breath. If I knew anyone at Timken I would ask. Might still be due to pandemic and supply issues.
Nv Bob
- First Name: Bob
- Last Name: Middleton
- * REQUIRED* Type and Year of Model Ts owned: 18 roadster 1810 brand X
Re: Timken
Amazon beat rock auto and if you have prime free shipping
Get all except the threaded outer bearing
Re: Timken
I did a comparison for TIMKEN 09194 - plus shipping,
NOTE if you select AMAZON as the sellers shipping requires an order of $25 or more.
So the number of items being purchased from the same supplier needs to be considered for a shipping total
For this 1 item TIMKEN 09194 with shipping the least expensive was RockAuto, next eBay or Amazon (depends on which offer you select and if you have Prime)
Re: Timken
Thanks Allen! I've been so busy, causing me to be remiss in staying on it. I'll order a couple today!
Re: Timken
Tim,
I thought you needed bearings. If you order races, you will be sadly disappointed. They are not interchangable.
9075 is the only item not available. This has been a problem for at least a year.
ChrisB
- First Name: Chris
- Last Name: Brancaccio
- * REQUIRED* Type and Year of Model Ts owned: 1909 Roadster 1915 Coupelet 1923 Coupe 1926 Touring
Back in stock, got mine today.
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
MTFCA Webmaster
MTFCA Forum Admin
Re: Timken front wheel bearings
Who has them Chris? Better PM me so all the lurkers here don't jump the queue.
Just looked RockAuto
ChrisB
- First Name: Chris
Yes got mine from Rock Auto.
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
MTFCA Webmaster
MTFCA Forum Admin
Mine are ordered and arriving next week.
ChrisB
- First Name: Chris
Anyone had any problems with the new supply?
I tried to install one today and it will not screw on all the way, it's like when you mix a close metric thread to a SAE one.
I tried it on 2 different spindles and also tried both bearings with the same result.
Chris
PS as mentioned above it is the left bearing with the regular threads 09075
Chris
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
MTFCA Webmaster
MTFCA Forum Admin
AZTerry
- First Name: Terry
- Last Name: Loftus
- * REQUIRED* Type and Year of Model Ts owned: 26 Speedster
I have seen this problem several times in the past. I take a thread file to the spindle to clean up the threads. A helical wire brush on the inside threads of the bearing may help as well.
Terry
Terry
