Timken front wheel bearings
Algonac27
First Name: Dale
Last Name: Williams
* REQUIRED* Type and Year of Model Ts owned: 1910 Touring, 1913 Touring, 1920 Coupe & Touring
Post by Algonac27 » Fri Nov 25, 2022 7:02 pm
Would anyone have the Timken numbers for outer and inner front bearings.
Last Name: Strange
Re: Timken
Post by CudaMan » Fri Nov 25, 2022 7:37 pm
A Google search for "timken front wheel bearings mtfca" revealed this older thread:
http://www.mtfca.com/discus/messages/70 ... 1511123413
Jeepbone1
First Name: Brad
Last Name: Kirtner
* REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
Re: Timken
Post by Jeepbone1 » Fri Nov 25, 2022 7:41 pm
Here you go.
Brad
Re: Timken
Post by Steve Jelf » Fri Nov 25, 2022 10:34 pm
Rock auto usually has the best prices on those, IF they're in stock.
Algonac27
First Name: Dale
Last Name: Williams
Re: Timken
Post by Algonac27 » Fri Nov 25, 2022 10:37 pm
Thanks guys!!!
Last Name: Wrenn
Re: Timken
Post by TWrenn » Sat Nov 26, 2022 10:14 am
It's been so long since I've heard from Rock Auto, but if my lame brain is correct, I"m STILL waiting for the inside left bearing...or maybe it was the right side, or even both! Ha ha. Point is, they're mostly unobtanium for some stupid reason. :evil:
Re: Timken
Post by TRDxB2 » Sat Nov 26, 2022 11:15 am
Rock Auto prices & availability TIMKEN 09075 doesn't look it is available anywhere but some sites indicate end of this year or January 2023
Re: Timken
Post by Allan » Sat Nov 26, 2022 7:18 pm
Tim, it's the outer bearing that is out of stock. I have right hand bearing on back order with Langs, and no indication of availability. They have the left ones.
Last Name: Hjortnaes
Re: Timken
Post by DHort » Sat Nov 26, 2022 7:30 pm
Rock Auto will notify you when 9075 is available. However, they have had to renew my request 2-3X because my request has been in their system so long. If I hear anything I will post it on here, but dont hold your breath. If I knew anyone at Timken I would ask. Might still be due to pandemic and supply issues.
Nv Bob
First Name: Bob
Last Name: Middleton
Re: Timken
Post by Nv Bob » Sun Nov 27, 2022 12:02 am
Amazon beat rock auto and if you have prime free shipping
Get all except the threaded outer bearing
Re: Timken
Post by TRDxB2 » Sun Nov 27, 2022 1:32 am
I did a comparison for TIMKEN 09194 - plus shipping,
NOTE if you select AMAZON as the sellers shipping requires an order of $25 or more.
So the number of items being purchased from the same supplier needs to be considered for a shipping total
For this 1 item TIMKEN 09194 with shipping the least expensive was RockAuto, next eBay or Amazon (depends on which offer you select and if you have Prime)
Last Name: Wrenn
Re: Timken
Post by TWrenn » Sun Nov 27, 2022 8:56 am
Thanks Allen! I've been so busy, causing me to be remiss in staying on it. I'll order a couple today!
Re: Timken
Post by DHort » Sun Nov 27, 2022 1:47 pm
Tim,
I thought you needed bearings. If you order races, you will be sadly disappointed. They are not interchangable.
9075 is the only item not available. This has been a problem for at least a year.
ChrisB
First Name: Chris
Last Name: Brancaccio
Post by ChrisB » Tue Dec 06, 2022 12:50 pm
Back in stock, got mine today.
Timken 09075
Timken 09075
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
Re: Timken front wheel bearings
Post by Allan » Tue Dec 06, 2022 5:12 pm
Who has them Chris? Better PM me so all the lurkers here don't jump the queue. :D :D
Post by TRDxB2 » Tue Dec 06, 2022 5:49 pm
Just looked RockAuto
ChrisB
First Name: Chris
Post by ChrisB » Tue Dec 06, 2022 11:03 pm
Yes got mine from Rock Auto.
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
Post by DHort » Wed Dec 07, 2022 11:49 am
Mine are ordered and arriving next week.
ChrisB
First Name: Chris
Post by ChrisB » Wed Aug 23, 2023 2:08 pm
Anyone had any problems with the new supply?
I tried to install one today and it will not screw on all the way, it's like when you mix a close metric thread to a SAE one.
I tried it on 2 different spindles and also tried both bearings with the same result.
Chris
PS as mentioned above it is the left bearing with the regular threads 09075
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
AZTerry
First Name: Terry
Last Name: Loftus
* REQUIRED* Type and Year of Model Ts owned: 26 Speedster
Post by AZTerry » Wed Aug 23, 2023 2:48 pm
I have seen this problem several times in the past. I take a thread file to the spindle to clean up the threads. A helical wire brush on the inside threads of the bearing may help as well.
Terry
