I am starting on restoring my 26 Canadian coupe and I will have to replace all the interior window moulding screws (and probably install a bunch of “nutserts” as well. Being a 26 all the screws are installed into metal and are not sheet metal type. Being Canadian they are all Robertson head. So trying to figure out what thread pitch I’m looking for??
Thank you
Thread pitch question
Les Schubert
Topic author - Posts: 1364
- First Name: Les
- Last Name: Schubert
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
Re: Thread pitch question
My stash of leftover “clinch” nuts (D shaped nut inserts that swedge into the sheet metal) says #10-32 and 1/4”-20. These are leftover from my ‘ol 27 roadster
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Most are 10-32, a few are 12-24, 8-32, and 6-32.
Les Schubert
- First Name: Les
10-32 sounds reasonable!!
Thanks Kevin
Thanks Kevin
Les Schubert
- First Name: Les
Thanks Kevin
I will keep trying to recover some original to check.
Thanks Kevin
Paperman
- First Name: Robert
- Last Name: Kesling
If you find a distributor for new correct hardware let me know, I too am working on a late Canadian car. It’s nice finding all the Made in Canada cast onto the parts. Pretty unique amongst T’s around here.
