Thread pitch question
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Mon Aug 28, 2023 6:35 pm
I am starting on restoring my 26 Canadian coupe and I will have to replace all the interior window moulding screws (and probably install a bunch of “nutserts” as well. Being a 26 all the screws are installed into metal and are not sheet metal type. Being Canadian they are all Robertson head. So trying to figure out what thread pitch I’m looking for??
Thank you
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Thread pitch question
Post by Kevin Pharis » Mon Aug 28, 2023 7:30 pm
My stash of leftover “clinch” nuts (D shaped nut inserts that swedge into the sheet metal) says #10-32 and 1/4”-20. These are leftover from my ‘ol 27 roadster
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Mon Aug 28, 2023 7:33 pm
Most are 10-32, a few are 12-24, 8-32, and 6-32.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Mon Aug 28, 2023 7:35 pm
10-32 sounds reasonable!!
Thanks Kevin
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Mon Aug 28, 2023 7:36 pm
Thanks Kevin
I will keep trying to recover some original to check.
Paperman
Last Name: Kesling
* REQUIRED* Type and Year of Model Ts owned: 1927 Tudor
Post by Paperman » Mon Aug 28, 2023 8:57 pm
If you find a distributor for new correct hardware let me know, I too am working on a late Canadian car. It’s nice finding all the Made in Canada cast onto the parts. Pretty unique amongst T’s around here.
