Ruckstell Data Plate
JBog
First Name: Jason
Last Name: Bogstie
Post by JBog » Sun Sep 17, 2023 9:48 pm
I'm rebuilding my Ruckstell and the data plate was obliterated. I have the right replacement but can someone tell me what size the serial number is so I can get the correct punches?
Re: Ruckstell Data Plate
Post by TRDxB2 » Sun Sep 17, 2023 11:44 pm
Looks like any may work
Susanne
First Name: Susanne
Last Name: Rohner
Post by Susanne » Mon Sep 18, 2023 11:21 am
Upper left plate is the one I see a lot, the lower right (earlier) is similar, but they both have the same "number font" as the 8 sided (later) one.
Post by Original Smith » Mon Sep 18, 2023 11:29 am
There are at least two versions of the common retangular data plate, early and late. The clipped corners plate was introduced when Eaton took over the manufacturing of the Ruckstell's. It can be found on small drum Ruckstell's as well as the big drum models.
Post by speedytinc » Mon Sep 18, 2023 11:57 am
All the original tags have the same font as the upper left. Note, its not a run of the mill stamp letter type.
I believe the stamps were in a multi stamp holder. The #'s are always perfectly in line.
I can measure the font height on an original tag tonight.
JBog
First Name: Jason
Last Name: Bogstie
Post by JBog » Mon Sep 18, 2023 1:11 pm
That would be great, thank you!
MarkS
Last Name: Sumner
* REQUIRED* Type and Year of Model Ts owned: 1915 Ford Model T Touring
Post by MarkS » Mon Sep 18, 2023 5:52 pm
I believe my Ruckstell is a fairly early one; it has the early brass shifter housing. The numbers on my tag are 0.10” tall, and from the left side of the 3 to the right side if the 8 measures 0.50”. While the numbers are not “perfectly” aligned vertically, because they are not rotated and are pretty evenly spaced I tend to concur that some type of fixture was probably used for alignment.
Post by speedytinc » Tue Sep 19, 2023 7:56 pm
It is a 3/32 stamp.
JBog
First Name: Jason
Last Name: Bogstie
Post by JBog » Tue Sep 19, 2023 8:03 pm
Thank you!
modeltspaz
Last Name: Spaziano
Post by modeltspaz » Tue Sep 19, 2023 8:18 pm
The font type is called Benjamin Franklin.
I'll post a link below for a set of steel number stamps at a pretty affordable price. Better hurry, though. It shows one set left.
https://www.lockpicks.com/number-stamp-set-3-32.html
