Cleaning NH Carburetor
ABoer
First Name: Anthonie
Last Name: Boer
* REQUIRED* Type and Year of Model Ts owned: 1912 touring 1923 roadster 1925 pickup
Post by ABoer » Wed Nov 01, 2023 6:42 am
What is the best way to clean the inside canals of a NH Carburetor .
Thanks for your answer .
Toon
M.Sinclair
First Name: Matthew
Last Name: Sinclair
* REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1919 Runabout
Re: Cleaning NH Carburetor
Post by M.Sinclair » Wed Nov 01, 2023 7:23 am
Ive heard that you should have them vaporblasted usually motorcycle shops can do that.
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Wed Nov 01, 2023 9:18 am
There are brass plugs at the end of each passage. Remove the plugs and soak the carb in carb cleaner. I use an ultrasonic cleaner. Use a wire through the passages to ensure there’s nothing in there. You can plug the passages back up with soft brass like brazing rod. Vapor blasting will make it pretty but won’t clean the passages which are really the important part.
Andy
jiminbartow
Last Name: Patrick
Post by jiminbartow » Wed Nov 01, 2023 10:28 am
I have always had good luck with the spray type, Xylene based aerosol cleaners with the red small tube that allows for high pressure spraying into the passageways. “Gumout” is a good example but there are all types of brands which work equally well. Jim Patrick
Post by Norman Kling » Wed Nov 01, 2023 11:40 am
I have soaked in acetone overnight. Then blow out all passages with compressed air. Usually no need to remove plugs. If the idle still doesn't work satisfactorily, then the plugs will need to be removed and do as Andy says above.
Post by TRDxB2 » Wed Nov 01, 2023 12:24 pm
Toon
Here are complete disassembly, cleaning & reassembly instructions - step by step with pictures etc
https://modeltfordfix.com/rebuilding-th ... el-t-ford/
Don't forget to get one of Scott Conger's Float-Valves
This one covers a few extra things to do https://www.mtfca.com/discus/messages/4 ... 1402151664
Last Name: Hatch
Post by Dan Hatch » Wed Nov 01, 2023 12:44 pm
Order the club carburetor book. Everything you need.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Wed Nov 01, 2023 1:20 pm
Andy
I did not have brazing rod but my hardware store had brass screws. I cut pieces from the screw shank.
