OHV Head #78 Unknown ID
JSteele
First Name: John P.
Last Name: Steele
* REQUIRED* Type and Year of Model Ts owned: 1915 Roadster
Post by JSteele » Tue Nov 14, 2023 10:36 pm
I picked up another project. I think it's project #6093 on my list. The head is the first mystery I'm trying to solve so I thought I would post some pictures and see if anyone knows. It has been suggested that it was for a marine engine which could be possible but I believe this head was sold with accessories or as a package for street use.
Port is really well divided
Cross flow head
Cross flow head
individual rocker arms stands
JSteele
First Name: John P.
Last Name: Steele
Re: OHV Head #78 Unknown ID
Post by JSteele » Tue Nov 14, 2023 10:48 pm
Rocker arm and some pictures of water heated manifold
primer cup
primer cup
front of intake
front of intake
Top of intake
Top of intake
Intake serial # 78
Intake serial # 78
rocker arm part #33512
JSteele
First Name: John P.
Last Name: Steele
Post by JSteele » Tue Nov 14, 2023 10:57 pm
Exhaust system/ push rods/ Beehive valve springs
horseshoe clip holding valve spring retainer in place
push rod end
push rod end
push rod
push rod
Cast iron piece flex tube fasten to, nice casting
Exhaust manifold cast head with flex pipe
JSteele
First Name: John P.
Last Name: Steele
Post by JSteele » Tue Nov 14, 2023 11:08 pm
Head Gasket Fitzgerald
Never Leak
Gasket
Bound To
Be Good
201
Anybody know what years this company was in business making Model T Head Gaskets
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Wed Nov 15, 2023 12:02 am
That’s an interesting gasket variation as it has the push rod pass thru hole at the full valve diameter. This extra clearance is needed on a select few O/H conversions that utilize the ports in the block. One example is the Roof 16 valve model “A” cylinder head
Post by TXGOAT2 » Wed Nov 15, 2023 9:10 am
Mr. Fitzgerald made his first gaskets for the Breech Block spark plug.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Wed Nov 15, 2023 9:17 am
got10carz
Last Name: Meixner
* REQUIRED* Type and Year of Model Ts owned: 1911,13,14,19,23,25,26,27
Post by got10carz » Wed Nov 15, 2023 9:32 am
My 16 valve had a Fitzgerald head gasket when I took it apart. I don't remember the part number, and I'm sure I threw it away.
Duey_C
First Name: Duane
Last Name: Cooley
Post by Duey_C » Thu Nov 16, 2023 1:53 am
Thank you for the Fitzgerald info Ed. :)
There's a pair of Fitz #728's here which are far, far from this realm. ;)
