OHV Head #78 Unknown ID
Topic author - Posts: 146
- First Name: John P.
- Last Name: Steele
- * REQUIRED* Type and Year of Model Ts owned: 1915 Roadster
I picked up another project. I think it's project #6093 on my list. The head is the first mystery I'm trying to solve so I thought I would post some pictures and see if anyone knows. It has been suggested that it was for a marine engine which could be possible but I believe this head was sold with accessories or as a package for street use.
- Attachments
- Port is really well divided
- IMG_2199.jpg (23.09 KiB) Viewed 2354 times
- Cross flow head
- IMG_2198.jpg (53.06 KiB) Viewed 2354 times
- individual rocker arms stands
- IMG_2202.jpg (57.97 KiB) Viewed 2354 times
- IMG_2193.jpg (24.53 KiB) Viewed 2354 times
- IMG_2192.jpg (26.9 KiB) Viewed 2354 times
- Last Name: Steele
Re: OHV Head #78 Unknown ID
Rocker arm and some pictures of water heated manifold
- Attachments
- primer cup
- IMG_2218.jpg (21.22 KiB) Viewed 2341 times
- front of intake
- IMG_2213.jpg (25.84 KiB) Viewed 2341 times
- Top of intake
- IMG_2215.jpg (57.2 KiB) Viewed 2341 times
- Intake serial # 78
- IMG_2210.jpg (16.26 KiB) Viewed 2341 times
- rocker arm part #33512
- IMG_2204.jpg (62.13 KiB) Viewed 2341 times
- Last Name: Steele
Exhaust system/ push rods/ Beehive valve springs
- Attachments
- horseshoe clip holding valve spring retainer in place
- IMG_2223.jpg (50.87 KiB) Viewed 2335 times
- push rod end
- IMG_2222.jpg (50.67 KiB) Viewed 2335 times
- push rod
- IMG_2221.jpg (53.35 KiB) Viewed 2335 times
- Exhaust manifold cast head with flex pipe
- IMG_2226.jpg (55.8 KiB) Viewed 2335 times
- Last Name: Steele
Head Gasket Fitzgerald
Never Leak
Gasket
Bound To
Be Good
201
Anybody know what years this company was in business making Model T Head Gaskets
Never Leak
Gasket
Bound To
Be Good
201
- Attachments
- IMG_2245.jpg (58.54 KiB) Viewed 2332 times
- IMG_2240.jpg (24.59 KiB) Viewed 2332 times
- IMG_2244.jpg (56.96 KiB) Viewed 2332 times
- Last Name: Pharis
That’s an interesting gasket variation as it has the push rod pass thru hole at the full valve diameter. This extra clearance is needed on a select few O/H conversions that utilize the ports in the block. One example is the Roof 16 valve model “A” cylinder head
Mr. Fitzgerald made his first gaskets for the Breech Block spark plug.
- First Name: Ed
- Last Name: Martin
- Last Name: Meixner
My 16 valve had a Fitzgerald head gasket when I took it apart. I don't remember the part number, and I'm sure I threw it away.
- First Name: Duane
- Last Name: Cooley
Thank you for the Fitzgerald info Ed.
There's a pair of Fitz #728's here which are far, far from this realm.
