Accessory shock ?
tom_strickling
Topic author - Posts: 441
- First Name: Tom
- Last Name: Strickling
- * REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 Roadster,snowmobile, Shaw tractor conversion
Accessory shock ?
Ever see one of these before??
ThreePedalTapDancer
- First Name: Ed
- Last Name: Martin
Re: Accessory shock ?
Yes it’s an accessory single shock absorber. Interesting and desirable. I’ve seen one other in my travels.
Moxie26
- Last Name: Jablonski
Too bad the main leaf is in pieces
Road salt.
warwick_preval
- First Name: warwick
- Last Name: preval
- * REQUIRED* Type and Year of Model Ts owned: 25 tr 22 coupe
- Board Member Since: 2014
Hello All, can someone tell me what type of brake drum or drums that is in this photo cheers Warwick.
tom_strickling
- First Name: Tom
Looks like drums added overtop of the Ford drum for accessory brakes such as Rocky Mountains. The car had small brake drums, but the accessory drum is larger.
warwick_preval
- Last Name: preval
THANKS Tom cheers Warwick.
John Codman
- Last Name: Codman
I would remove that accessory shock absorber before I ever drove that car (from what I see my guess is that is a ways off). It is putting loads on parts that were not designed to take them.
ThreePedalTapDancer
- First Name: Ed
- Last Name: Martin
The shock uses heavy cast formed brackets on the top and rear end. You can adjust the tension to get desired spring action. I’ve seen a brass case one before. Since I like weird accessories, I’d run it myself just to confuse and baffle other T owners. I’d reduce the spring tension if any concerns about design.
