Accessory shock ?
tom_strickling
Last Name: Strickling
* REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 Roadster,snowmobile, Shaw tractor conversion
Accessory shock ?
Post by tom_strickling » Tue Dec 05, 2023 5:09 pm
Ever see one of these before??
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Re: Accessory shock ?
Post by ThreePedalTapDancer » Tue Dec 05, 2023 6:21 pm
Yes it’s an accessory single shock absorber. Interesting and desirable. I’ve seen one other in my travels.
Moxie26
Last Name: Jablonski
Post by Moxie26 » Tue Dec 05, 2023 7:29 pm
Too bad the main leaf is in pieces
Post by TXGOAT2 » Tue Dec 05, 2023 7:47 pm
Road salt.
warwick_preval
First Name: warwick
Last Name: preval
* REQUIRED* Type and Year of Model Ts owned: 25 tr 22 coupe
Board Member Since: 2014
Post by warwick_preval » Wed Dec 06, 2023 7:36 am
Hello All, can someone tell me what type of brake drum or drums that is in this photo cheers Warwick.
tom_strickling
Post by tom_strickling » Wed Dec 06, 2023 10:09 pm
Looks like drums added overtop of the Ford drum for accessory brakes such as Rocky Mountains. The car had small brake drums, but the accessory drum is larger.
warwick_preval
First Name: warwick
Last Name: preval
Post by warwick_preval » Thu Dec 07, 2023 6:54 am
THANKS Tom cheers Warwick.
John Codman
Last Name: Codman
Post by John Codman » Thu Dec 07, 2023 12:42 pm
I would remove that accessory shock absorber before I ever drove that car (from what I see my guess is that is a ways off). It is putting loads on parts that were not designed to take them.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Sat Dec 09, 2023 10:10 am
The shock uses heavy cast formed brackets on the top and rear end. You can adjust the tension to get desired spring action. I’ve seen a brass case one before. Since I like weird accessories, I’d run it myself just to confuse and baffle other T owners. I’d reduce the spring tension if any concerns about design.
