shocks
Philip
Topic author - Posts: 239
- First Name: Philip
- Last Name: Thompson
Re: shocks
there was a thread on the subject but i have no luck searching anymore
- Last Name: Strange
Re: shocks
Philip
Re: shocks
thanks mark i found that one there is one somewhere that shows the fronts
MichaelPawelek
- First Name: Michael
- Last Name: Pawelek
Re: shocks
Phillip, In the past on a Touring and a Coupe I found the ride greatly smoothed out by refurbishing and lubricating both front and rear springs. A stiff ride is generally an indication of worn and non lubricated spring set up. The Model T rides quite comfortably when the springs are in good shape…
Rich P. Bingham
- First Name: Rich
- Last Name: Bingham
Re: shocks
Another aspect of "ride" is tires. Recently changed out old rock-hard tires for new, fresh, pliable tires and the difference was remarkable!
Get a horse !
Bill Mullins
- First Name: Bill
- Last Name: Mullins
- * REQUIRED* Type and Year of Model Ts owned: 1927 Tudor
Re: shocks
My method is using 1965 & earlier VW shocks front & rear.They work very well as Tom says the rear make the big difference.
Bill Mullins
- First Name: Bill
Re: shocks
- First Name: Austin
- Last Name: Farmer
Re: shocks
Its not your fault, its googles fault. It wont show mtfca search results anymore.
If you switch to a different search engine you may have more luck with a search.
Philip
Re: shocks
bill can you give me a picture of the mounts?
SurfCityGene
- First Name: Gene
- Last Name: Carrothers
Re: shocks
Philip, The ones I have seen on the NW Montana 500 racers where smaller VW type and attached directly to the differential tube. They were Much less offensive looking than some others but not Model T era for sure. If you can find a picture of Tom's I would copy his idea and could easily be home built.
1912 Torpedo Roadster
