Did this fall off of my car?
colonelpowers
First Name: Joshua
Last Name: Powers
* REQUIRED* Type and Year of Model Ts owned: 1922 Center Door Sedan
Post by colonelpowers » Mon Jun 24, 2024 5:20 pm
I was getting out of my 22 Center Door and found this on the running board. I can't place what it is but I thought I would ask the experts. Any ideas?
Re: Did this fall off of my car?
Post by Norman Kling » Mon Jun 24, 2024 5:23 pm
Looks like a clamp to hold wiring in place. Usually found around the front of the engine near the radiator hose for the low voltage wires from the timer or for the wires on firewall or hood sills.
Tekirgis
Last Name: Kirgis
* REQUIRED* Type and Year of Model Ts owned: 1926 fordoor
Board Member Since: 2024
Post by Tekirgis » Mon Jun 24, 2024 5:34 pm
On my 26 fordoor there is a clip like that for the gasline at one point on the frame and what you have is 1/2 of it . But your car is different from mine so not sure about your car.
Last Name: Patrick
Post by jiminbartow » Mon Jun 24, 2024 6:57 pm
Battery hold down clamp?
vping
First Name: Vincent
Last Name: Pina
Post by vping » Mon Jun 24, 2024 7:02 pm
They are on either side of the engine bay, holding the headlight wires in place.
Post by John kuehn » Mon Jun 24, 2024 8:01 pm
Looks like a wiring clamp.
colonelpowers
First Name: Joshua
Last Name: Powers
Post by colonelpowers » Mon Jun 24, 2024 8:09 pm
I think that you are exactly right. It looks like half of that holder but that makes for a great mystery; how in the world could it have made it from where it goes to where I found it?
Thanks so much for your help. You always know the answers.
Last Name: Patrick
Post by jiminbartow » Mon Jun 24, 2024 8:18 pm
Referred to as a gas line clamp set in Snyder’s parts. Wire clips have a deeper U, don’t require a second half and are not made of such thick steel.
Gas line clamp set
Light cable clip
Moxie26
Last Name: Jablonski
Post by Moxie26 » Mon Jun 24, 2024 8:20 pm
U S. Quarters we're not used on Model T. Fords. Buffalo nickels were used as freeze plugs in the block when the Ford issues rusted out.
Post by Allan » Mon Jun 24, 2024 9:01 pm
Our Canadian car use those clips, in pairs, to hold the headlight wire looms in place. One pair on the left at the front, two pairs on the right. All are sandwiched between the frame and hood shelf blocks and held in place by the hood shelf bolts. The other wiring clips do have a deeper U, are of lighter material, but are used singularly, usually to hold the looms on the firewall.
Post by Jerry VanOoteghem » Mon Jun 24, 2024 9:17 pm
Referred to as a gas line clamp set in Snyder’s parts. Wire clamps have a deeper U, don’t require a second half and are not made of such thick steel.
Jim,
They're used for that too. They are also wiring clamps.
