Did this fall off of my car?
colonelpowers
Topic author - Posts: 225
- First Name: Joshua
- Last Name: Powers
- * REQUIRED* Type and Year of Model Ts owned: 1922 Center Door Sedan
I was getting out of my 22 Center Door and found this on the running board. I can't place what it is but I thought I would ask the experts. Any ideas?
Re: Did this fall off of my car?
Looks like a clamp to hold wiring in place. Usually found around the front of the engine near the radiator hose for the low voltage wires from the timer or for the wires on firewall or hood sills.
Tekirgis
- First Name: Tom
- Last Name: Kirgis
- * REQUIRED* Type and Year of Model Ts owned: 1926 fordoor
- Board Member Since: 2024
On my 26 fordoor there is a clip like that for the gasline at one point on the frame and what you have is 1/2 of it . But your car is different from mine so not sure about your car.
- Last Name: Patrick
Battery hold down clamp?
vping
- First Name: Vincent
- Last Name: Pina
- * REQUIRED* Type and Year of Model Ts owned: 1925 Tudor Sedan
They are on either side of the engine bay, holding the headlight wires in place.
Looks like a wiring clamp.
colonelpowers
- Last Name: Powers
I think that you are exactly right. It looks like half of that holder but that makes for a great mystery; how in the world could it have made it from where it goes to where I found it?
Thanks so much for your help. You always know the answers.
Referred to as a gas line clamp set in Snyder’s parts. Wire clips have a deeper U, don’t require a second half and are not made of such thick steel.
Gas line clamp set
Light cable clip
Gas line clamp set
Light cable clip
Moxie26
- Last Name: Jablonski
U S. Quarters we're not used on Model T. Fords. Buffalo nickels were used as freeze plugs in the block when the Ford issues rusted out.
Our Canadian car use those clips, in pairs, to hold the headlight wire looms in place. One pair on the left at the front, two pairs on the right. All are sandwiched between the frame and hood shelf blocks and held in place by the hood shelf bolts. The other wiring clips do have a deeper U, are of lighter material, but are used singularly, usually to hold the looms on the firewall.
Jim,jiminbartow wrote: ↑Mon Jun 24, 2024 8:18 pmReferred to as a gas line clamp set in Snyder’s parts. Wire clamps have a deeper U, don’t require a second half and are not made of such thick steel.
They're used for that too. They are also wiring clamps.
